Kitten rear axle
For other Reliants.
Been thanked: 225 times
Kitten rear axle
Post by AJL Electronics » Tue Oct 20, 2015 2:41 pm
Just had an MOT and they noticed that the rear axle didn't look square. I have also had a brake judder that I couldn't get to the bottom of. So, investigating, the axle was over an inch too far back on the driver's side. When taking it apart, the locating peg from the spring to the axle mount was in the offset hole, not the centre one as per left side. Dealt with all that ans hopefully the test drive may show that the brake judder is sorted.
Been thanked: 340 times
Re: Kitten rear axle
Post by peter freeman » Tue Oct 20, 2015 8:49 pm
I always found that brake judder was due to the front drum brakes - fitting discs was always the best mod to do on the Kitten.
Post by AJL Electronics » Tue Oct 20, 2015 9:39 pm
Well the brake judder has now gone!
Post by peter freeman » Tue Oct 20, 2015 10:13 pm
But can you always brake in a straight line - I never knew which way the car was going to go - which made me a very careful driver when out in the kitten - I still wish I had kept it.
