Another plastic car project...
For other Reliants.
Coelhomaluco
Re: Another plastic car project...
Post by Coelhomaluco » Thu Sep 25, 2014 6:05 pm
will have to research into that as I have no idea how to figure that out yet...
1976 Kitten "patina look" here
Coelhomaluco
Post by Coelhomaluco » Fri Sep 26, 2014 6:51 pm
Might have a Engine coming this weekend... Anyone has any idea where to get the wiring diagram for the kitten? I think I have part of it missing (ie battery connections). Another question, is there anyone that can cut me a key for the ignition and doors using the barrel to do it? The previous owner couldnt find them...
Been thanked: 210 times
Post by AJL Electronics » Fri Sep 26, 2014 7:10 pm
I have a workshop manual. Have a look if you are coming on Sunday.
Coelhomaluco
Post by Coelhomaluco » Fri Sep 26, 2014 7:16 pm
Will be picking up the Engine on Sunday, so yes, will have a look when I drop by on the way back. Thanks.
Marmaduke
Post by Marmaduke » Fri Sep 26, 2014 7:43 pm
scimjim wrote:I doubt you'll need a servo with discs and a standard engine - just make sure the master cylinder is the right size.
I can definitely confirm you won't need a servo so long as your standard master cylinder is in good nick - I've driven a tempest with disks and no servo and the braking was very impressive - certainly your able to lock the wheels if you really want to :wink: I've heard that the MOT man was so impressed by the efficiency of the setup that he couldn't believe that the fiesta/polo combo didn't have a servo !
1985 SS1 - What the Cipher dreams of driving like...
1980 Cipher - What the SS1 dreams of looking like...
Marmaduke
Post by Marmaduke » Fri Sep 26, 2014 7:47 pm
Coelhomaluco wrote:Might have a Engine coming this weekend... Anyone has any idea where to get the wiring diagram for the kitten? I think I have part of it missing (ie battery connections). Another question, is there anyone that can cut me a key for the ignition and doors using the barrel to do it? The previous owner couldnt find them...
The door locks use the old Union FS type of keys - I think (not sure though) there is a number on the lock barrel that tells you - you could then get a suitable key cut.
The ignition key is a bit more problematic - it may be easier to replace the whole lock - do you have the kind that is attached to the steering column or one of the ones set on a small panel ?
Been thanked: 842 times
Post by scimjim » Fri Sep 26, 2014 7:58 pm
The kitten wiring diagram would fit on the back of a fag packet :-)
Poppy
Post by Poppy » Fri Sep 26, 2014 9:19 pm
There is a Haynes manual on the Robin and Kitten, including a circuit diagram. They often come up on Ebay.
Tony
Coelhomaluco
Post by Coelhomaluco » Fri Sep 26, 2014 10:07 pm
Its the one on the steering column. Looks similar to the one on the Scimitar.
Coelhomaluco
Post by Coelhomaluco » Fri Sep 26, 2014 10:08 pm
scimjim wrote:The kitten wiring diagram would fit on the back of a fag packet :-)
Those are the kind I like the best... hehe
Coelhomaluco
Post by Coelhomaluco » Fri Sep 26, 2014 10:11 pm
Poppy wrote:There is a Haynes manual on the Robin and Kitten, including a circuit diagram. They often come up on Ebay.
Tony
And they are not too expensive... Will get me one as soon as the other half approves (need to fill the forms and all that) :lol:
Marmaduke
Post by Marmaduke » Fri Sep 26, 2014 10:25 pm
I think they are same as the scimitar kind - but not absolutely sure. I think it may well be easier and cheaper to replace the lock (my spare ignition key cost £10 to get cut) - best to talk to James at chgperformance (I think he's on here using that username) as he should have a few around.
Coelhomaluco
Post by Coelhomaluco » Fri Sep 26, 2014 10:29 pm
yeah, will replace the ignition and will try to salvage the door ones as its a simple key to get cut.
Has thanked: 138 times
Been thanked: 151 times
Post by Corky » Sat Sep 27, 2014 7:24 am
I had some keys cut for a pair NOS Range Rover Classic door handles I bought on eBay (for a GTC). They came without keys, which meant they were mega cheap. Expecting to have to buy new lock barrels, I took them down to my local lock smith. But he had a tool for reading the tumblers and quickly cut me a pair of keys to fit, for about £15.
Coelhomaluco
Post by Coelhomaluco » Sat Sep 27, 2014 8:07 am
That would be great if I could find somebody here that does the same job.
