Reliant Kitten parts wanted
For other Reliants.
Been thanked: 222 times
Post by AJL Electronics » Thu Aug 21, 2014 9:52 am
I want to convert from moulded door cards to flat panels, so that I can fit alternative seats. To be able to do the conversion, I need the door caps. Anyone got a pair cheap? Otherwise, what seats will fit the gap? Originals are about 450fm (funny money) wide. Cobra Clubmans fit well at 500 funny money but not with the moulded door cards.
It would also be nice to find a set of 12" Minilite wheels at under £100. I have 5j x 10" KN Gemini wheels currently which would then be for sale.
Lukeyboy46
Has thanked: 90 times
Been thanked: 37 times
Re: Reliant Kitten parts wanted
Post by Lukeyboy46 » Thu Aug 21, 2014 10:09 am
I would speak to Chgperformance?
He's likely to have something for you, or at least be able to source some.
Luke Garratt
RSSOC Forum Moderator
74' Se5a - Daily driver!
Post by AJL Electronics » Thu Aug 21, 2014 10:38 am
Thanks Luke. When he is feeling better I will do.
Been thanked: 27 times
Post by nickkeyser » Thu Aug 21, 2014 12:10 pm
I don't think I have any of the steel door caps unfortunately.
For seats SE6 ones fit nicely!
Post by AJL Electronics » Thu Aug 21, 2014 12:34 pm
Now that is interesting Nick!
Post by nickkeyser » Thu Aug 21, 2014 1:37 pm
Not the best pic, but this is mine;
Chgperformance
Post by Chgperformance » Thu Aug 21, 2014 2:17 pm
I do indeed have a pair of NOS door card top caps. Drop me a pm if you want :) I'm virtually in the land of the living again. Now on 100mg morphine twice a day plus 10mg every four hours if needed! Rediculous I know! Oh and Gabapentin on top of that!
Coelhomaluco
Post by Coelhomaluco » Mon Sep 22, 2014 6:03 pm
if se6 seats fit, se5a should fit even better, no? Reason I ask is I just bought one without interior, but not too bothered as just want 2 seats on it and have a couple of se5a ones spare... :)
also need to source a engine and gearbox (cheap and running would be great).
1976 Kitten "patina look" here
Post by nickkeyser » Mon Sep 22, 2014 6:39 pm
Not sure - my 6 ones fitted perfectly, picking up on two of the original holes but needing two more moving (the outer ones towards the door). I also have a nylon spacer under each of the front bolts.
Besides plugging these two holes and drilling two more they bolt directly in and onto the same steelwork as before. I doubt the 5 ones share the same bolt pattern but being small should fit fine.
Coelhomaluco
Post by Coelhomaluco » Mon Sep 22, 2014 8:02 pm
That's good... Or might just go the direction I was considering before and try some mx5 seats, they are used in hot rods for being narrow, so they might fit also...
Post by nickkeyser » Mon Sep 22, 2014 8:55 pm
Yup, seen those fitted in the past too.
Coelhomaluco
Post by Coelhomaluco » Mon Sep 22, 2014 9:31 pm
there might be other options for narrow seats. Bought the wife a Rover Streetwise (same as rover 25) and the seats on it seem really narrow and very comfortable, so it might be another option...
