Your thoughts on a random misfire.
mark rudder
Has thanked: 30 times
Post by mark rudder » Thu Aug 22, 2019 3:48 am
Interesting Roger, When operated the choke plate moves to a predetermined position, you can feel a slight "click",
more movement is available if required, high idle is fine. Andy, that makes sense as I've a running rather than a starting issue.
Of course it's behaving at the moment.....
Mark from down under.
Current GTE 6B, Scirocco R. Past Dolomite Sprint, XJS (manual), V12 E-type (manual, convertible, lovely) 350 chev XJ6, TR6, TR4, Sprite, Midget, local Ford V8s, others... There's a pattern here.….
mark rudder
Post by mark rudder » Fri Sep 20, 2019 3:48 am
Seem to have this sorted. Its a manual choke, pulling knob moves choke butterflies & sets high idle.
From cold, full choke, one pump, starts instantly, immediately to half choke, maintains high idle,
Once on road, choke in, six cylinders firing, We have a nice day.
Thanks all for the wisdom.
