GTC hardtop fixings
Coastline
Has thanked: 25 times
GTC hardtop fixings
Post by Coastline » Mon Jan 08, 2018 8:56 pm
GTC Hardtop
Can anyone help with some photos of the fixing method at the rear of the hardtop.
I have just removed the hardtop for the first time since buying the GTC and find it difficult to believe that the hard top was held on by just the two fixing to the front windscreen. I am sure that there must be some fixings at the rear but there are none visible.
Any help much appreciated.
ard126k
Been thanked: 27 times
GTC hardtop fixings
Post by ard126k » Mon Jan 08, 2018 9:11 pm
From the parts book -
Part 15 is a hook which goes into bracket 39 on the body and is fixed by the thumbscrew. My one has a slightly different arrangement, the hook has a thread on the top and a wingnut which can pull the whole thing down tight on to the body.
Alex.
1971 SE5 1977 SE6 1982 GTC
Has thanked: 153 times
Been thanked: 1042 times
GTC hardtop fixings
Post by scimjim » Mon Jan 08, 2018 9:11 pm
Two clips at the front, two brackets on the B posts and two at the rear.
http://www.scimitarweb.co.uk/sgwrs/view ... =3&t=35832
Coastline
GTC hardtop fixings
Post by Coastline » Mon Jan 08, 2018 10:11 pm
Many thanks Alex and Jim. With the photos and explanations all is becoming much clearer. I will take another look at mine tomorrow and see if the body clips are there. There were some bits and bobs in the glove box which may be the parts I am looking for.
ard126k
GTC hardtop fixings
Post by ard126k » Tue Jan 09, 2018 12:10 am
Just so you know what to look for the brackets for the B post are 17 and 18 on the drawing. The flat plates are screwed to the inside of the front of the hardtop and pull it against the b post.
Coastline
GTC hardtop fixings
Post by Coastline » Wed Jan 10, 2018 1:05 pm
I have taken a photo of what I found loose in the car. It looks as though I only have one of each plus another plate of some kind.
ard126k
GTC hardtop fixings
Post by ard126k » Wed Jan 10, 2018 2:09 pm
Think the long plate goes on the transmission tunnel beside the front seat, should be one each side. No idea what they're for though!!
David Buoy
GTC hardtop fixings
Post by David Buoy » Mon May 21, 2018 8:43 pm
Just got a 2nd hand hardtop and I’m mussing to 2 rear fixings. Did you manage to locate a supplier.
Coastline
GTC hardtop fixings
Post by Coastline » Mon May 21, 2018 8:52 pm
No I didn't find a supplier for the fixings, sorry.
David Buoy
GTC hardtop fixings
Post by David Buoy » Mon May 21, 2018 9:20 pm
Thanks for the quick reply.
Has thanked: 35 times
Been thanked: 158 times
GTC hardtop fixings
Post by gtcse8 » Mon May 21, 2018 10:25 pm
The rear fixings are in the centre of the above picture.
I Have been thinking about re manufacturing these in stainless rather than the plastic coated originals.
IF I can get enough interest I may make some??.
EX SST 1800Ti
jag12
GTC hardtop fixings
Post by jag12 » Tue May 22, 2018 12:36 am
Would definitely have a set from you
GTC GOC383W. GTE 6a PFG814R. SSI 1600. B46SNX
GTC hardtop fixings
Post by gtcse8 » Tue May 22, 2018 8:58 am
The Right hand plate looks like one of the clamping plates that are used to retain the carpet at the transmission tunnel and inside the centre cubby hole, they were used to spread the effort on retaining things, sometimes used at the bottom of the rear seat too.
EX SST 1800Ti
Coastline
GTC hardtop fixings
Post by Coastline » Tue May 22, 2018 9:35 am
I would have a set too Mark
Chimp
GTC hardtop fixings
Post by Chimp » Wed Sep 19, 2018 8:15 pm
Just noticed that I appear to have lost a rear hard top bracket. I can only assume it came loose and has fallen out of the car due to the gap when driving down the motorway. Mark did you manage to have any re-manufactured?
