Webcon Retrojet
Rob Jones
Webcon Retrojet
Post by Rob Jones » Tue Nov 14, 2017 8:12 pm
Good afternoon all,
Looking at installing the webcon retrojet onto my gtc, has anyone done this previously?.
Or does anyone know of installation of the system onto an alternative classic car?
Not doing it for anything other than it seems a great system to replace the carb and possibly ensure correct fuel burn.
Kind regards
Rob.
manny
Has thanked: 33 times
Webcon Retrojet
Post by manny » Tue Nov 14, 2017 8:21 pm
i am swaying towards this for my GTC- where are you located?
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Been thanked: 876 times
Webcon Retrojet
Post by scimjim » Tue Nov 14, 2017 8:53 pm
I have one which will possibly end up on the coupe with megasquirt.
manny
Webcon Retrojet
Post by manny » Tue Nov 14, 2017 9:01 pm
i know very little about the set up etc at the moment - but that's combination i will be going for- mainly as i am not too far from Aldon Automotive :D and they 're megasquirt friendly..
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
BusaPhill
Webcon Retrojet
Post by BusaPhill » Tue Nov 14, 2017 9:50 pm
Jenvey is another company that make aftermarket carb injection bodies.
Not cheap
If I was to build a system from scratch it would have a injector for each cylinder.
And MegaSquirt.
1979 Scimitar SE6A V6 3.1 4speed Auto
2005 Mercedes C320 V6 3.0 7speed Auto (Diesel Daily Driver).
manny
Webcon Retrojet
Post by manny » Wed Nov 15, 2017 7:54 am
Not cheap
And MegaSquirt.
I guess for me - it looks like a straight bolt in - looks standard ( although hidden) - and more importantly caters to my spanner rating - but you are right - if your're going spend the time\money\effort - do it properly to maximise the results
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Diyhell
Has thanked: 75 times
Webcon Retrojet
Post by Diyhell » Wed Nov 15, 2017 1:52 pm
I've also been looking at this idea. Whilst I'm a bit techie, am not sure about the degree in computing needed for a megasquirt?
SE6a needing lots of work...
Been thanked: 58 times
Webcon Retrojet
Post by Nick » Wed Nov 15, 2017 1:58 pm
The 38DGAS is about as good as carbs get. I get a complete 6 injector system as opposed to 3 carbs. Not sure of the real benefits of replacing a well set up DGAS with a throttle body and one or two injectors.
Been thanked: 551 times
Webcon Retrojet
Post by philhoward » Wed Nov 15, 2017 2:42 pm
Carb tuning gives you a fuelling curve that is basically 2 straight lines - one on the idle circuit and one for the main jet circuit. Going with an ECU allows you to plot a real curve, or even one with hills and valleys in it.
An injector (albeit slightly compromised running in a multi-cylinder-per-injector format) has much improved vaporisation over a carb - certainly an advantage from cold but will allow lean running on cruise as well as maximum fuelling when flat out that carbs rarely manage - they are a compromise that you have to bias to one end or the other.
Other advantages? No venturi (restriction) either needed or present. if going the whole hog with mappable ignition, then you get to optimise the ignition curve for all conditions of load and engine speed that a distributor can only dream of.
manny
Webcon Retrojet
Post by manny » Wed Nov 15, 2017 2:53 pm
How soon before it lives and breathes?
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Webcon Retrojet
Post by scimjim » Wed Nov 15, 2017 5:09 pm
In Power terms there may be no advantage over a single carb but there are plenty of advantages in terms of reliability and driveability. In addition to the more accurate fuel/air ratio across the complete spectrum from an ECU, injection gives you high pressure fuel delivery, which reduces the chances of fuel vaporisation - an increasing problem with more and more ethanol being added to our petrol.
Webcon Retrojet
No idea - it’s well down the list of projects :D
Webcon Retrojet
Post by Coupe Racing » Wed Nov 15, 2017 5:47 pm
I have a new triple manifold and 3 throttle bodies and 6 injectors
Just need the know how
Diyhell
Webcon Retrojet
Post by Diyhell » Tue Dec 12, 2017 9:49 pm
video of one here: https://www.youtube.com/watch?v=hFMZTEuU_j0
Very neat, all in one unit - I wonder whether it would limit it not having the separate ECU etc.
