Scimitar GTC Scuttle Shake
Rob Jones
Post by Rob Jones » Thu Aug 24, 2017 10:34 pm
Good afternoon al,
Having nearly completed my GTC restoration and driven to curborough and back, I was wondering, how much scuttle shake would you expect from a GTC.
When I hit bumps and holes, feels to me, the car shakes and rattles.
Kind regards
Rob
Has thanked: 41 times
Been thanked: 210 times
Post by AJL Electronics » Thu Aug 24, 2017 10:43 pm
Is the rollbar properly fixed to the chassis at the bottom?
Rob Jones
Post by Rob Jones » Thu Aug 24, 2017 10:45 pm
Yep, it's not a huge amount but it does not feel solid like a new drop head.
Been thanked: 840 times
Post by scimjim » Thu Aug 24, 2017 10:48 pm
This car was driven back from Holland and has been on the road for several years hasnt it?
So is this a new thing or has it always done it?
I'd start with springs and dampers including bushes, then the rest of the suspension bushes, also check that the body to suspension tower bolts haven't come loose.
petermisy
Post by petermisy » Thu Aug 24, 2017 11:04 pm
I done 340 miles in one day curborough and back, not a rattle or any scuttle shake totally solid. So I would say something is not right.
Peter
GTC Prototype XJW 247T
GTC No. 381 A381 GTC (was A24 EPB)
MGB GT 1971 EPE 838J (project)
2016 Ford Galaxy Titanium X 180bhp
Ford Transit Connect van
2016 Bailey Pegasus Verona Caravan
Post by greeny » Fri Aug 25, 2017 8:25 am
I think i would be looking at shocks and springs. Or maybe if the metal structure behind the dash not being fixed to the transmission tunnel?
Been thanked: 80 times
Post by gtcse8 » Fri Aug 25, 2017 9:45 am
Rob do you have the secondary door catches fitted and set up correctly, If they not a tight grip when the doors are shut you deffo get rattles.
""Or maybe if the metal structure behind the dash not being fixed to the transmission tunnel?""
Dave all my GTC`s have the "Metal structure" bolted to the A post/door hinge pillars.
Never come across anything in the middle of the car.
Post by greeny » Fri Aug 25, 2017 10:20 am
Mine has the h in the ctr that's bolted to the trans tunnel (that makes removing the heater box a total pig!!)
I thought I had a pic but I can't find it.
Post by scimjim » Fri Aug 25, 2017 11:04 am
The 6b/GTC additional bracing
Has thanked: 138 times
Been thanked: 149 times
Post by Corky » Fri Aug 25, 2017 11:45 am
I've not had scuttle shake in any of the GTCs I've owned, so would agree with the comments above.
