Fuel smell
Been thanked: 203 times
Re: Fuel smell
Post by AJL Electronics » Sun Jan 01, 2017 9:57 pm
Firstly, Gates genuine hose is difficult to find in this country and secondly, in my opinion (others will disagree) R6 is not Ethanol safe anyway. Minimum spec is R9 or better. Best of all is Cohline as sold in my webshop, details below. Your car, your life. What do you value them at?
Been thanked: 514 times
Re: Fuel smell
Post by philhoward » Sun Jan 01, 2017 10:06 pm
Hope you kept the receipt - take it back as not fit for purpose.
Has thanked: 113 times
Been thanked: 795 times
Re: Fuel smell
Post by scimjim » Sun Jan 01, 2017 10:09 pm
philhoward wrote:Hope you kept the receipt - take it back as not fit for purpose.
My point exactly.
R6 should be ethanol proof at low pressure (I tend to believe independent international standard laboratory tests :-))
Re: Fuel smell
Post by philhoward » Sun Jan 01, 2017 10:13 pm
If R6 is suitable for U.K. Unleaded then theirs is fake and should be removed from sale as a recall IMHO as they are selling unsafe components.
If it isn't, then they still shouldn't be selling it for the same reason.
If it had happened to me, I'd bypass them completely and go straight to Trading Standards but I've (luckily) got some OK R6 in stock and some of AJL's as well just in case.
metalmoth
Re: Fuel smell
Post by metalmoth » Mon Jan 02, 2017 2:12 pm
Ok I think I was a bit hasty blaming the new R6 hose as I have found the culprit. It appears that the plastic fuel line has split where it was inside the new hose possibly when the clip was tightened a few weeks ago. I used the correct clips thoughout. The split is about 10mm long . I shall now be replacing these with metal ones
1982 SE6b factory black aka The Beast
What could possibly go wrong?
Has thanked: 48 times
Been thanked: 76 times
Re: Fuel smell
Post by Oldconn » Mon Jan 02, 2017 3:00 pm
As a matter of habit, whenever you are clamping onto plastic tube, using an external circlip , you should have a metal sleeve INSIDE the end of the tube to prevent squashing or splitting. That was one of the first things I learned while training in a boat factory, where we had to installall manner of hydraulic,fuel and gas lines .
scmarf
Re: Fuel smell
Post by scmarf » Mon Jan 02, 2017 3:14 pm
Oldconn wrote:As a matter of habit, whenever you are clamping onto plastic tube, using an external circlip , you should have a metal sleeve INSIDE the end of the tube to prevent squashing or splitting. That was one of the first things I learned while training in a boat factory, where we had to installall manner of hydraulic,fuel and gas lines .
Interesting. Presumably not too thick metal sleeve to prevent a partial restriction? Don't remember seeing any on my cars but it does make sense or maybe the spring clip thingys are designed to grip but not crush?
Another line in Andy's fuel hose emporium maybe? :wink:
Honda Jazz
metalmoth
Re: Fuel smell
Post by metalmoth » Mon Jan 02, 2017 4:58 pm
I would post the picture of the pipe but I don't know how to do it. I am a bit of a dinosaur when it comes to these things!
Re: Fuel smell
Post by AJL Electronics » Mon Jan 02, 2017 5:09 pm
scmarf wrote:Don't remember seeing any on my cars but it does make sense
3mm sleeve in the expansion bottle return on SS1?
Dennis Nicholas
Has thanked: 17 times
Re: Fuel smell
Post by Dennis Nicholas » Mon Jan 02, 2017 5:13 pm
The correct clips to use when fitting the rubber over the nylon lines are those springy ones with the 3 ears. They provide more than enough pressure evenly around the circumference to hold everything in place and seal. The other jubilee type clips as used on water hoses will distort the hose/nylon..especially with over enthusiastic tightening thinking a better seal will be made.....don't ask how I know.......it's called experience.
Dennis
ps top quality fuel hose was from local largish motor factor in July 2015 for £7.90 per meter.
Dennis Nicholas(RSSOC)
Been thanked: 103 times
Re: Fuel smell
Post by ScimmyMike » Mon Jan 02, 2017 7:13 pm
Seemingly my filler setup has always been wrong then going off earlier comments, I've both flexy hose and metal parts internally fitted as when I took it apart, I guess I'll be taking the tank out again next weekend, not an enjoyable job at all in my opinion, still gives me a chance to rectify the cock up on the incorrect fitting of the sender unit that I paid a company to do and didn't realise till fitted that they'd welded the fixing ring outside the tank rather than inside meaning that it shows empty when there's 40 litres left in the tank due to it's raised height (I've VDO gauges fitted not standard ones)
metalmoth
Re: Fuel smell
Post by metalmoth » Mon Jan 02, 2017 11:15 pm
Can you use copper pipe instead of the plastic ones? Anybody done that front to rear?
Re: Fuel smell
Post by AJL Electronics » Mon Jan 02, 2017 11:35 pm
No, but you can use Kunifer.
metalmoth
Re: Fuel smell
Post by metalmoth » Tue Jan 03, 2017 12:08 am
Ok thanks
Dave McGregor
Re: Fuel smell
Post by Dave McGregor » Tue Jan 03, 2017 10:33 am
Why cant you use copper pipe?
