Not authorised
Can't register?
Been thanked: 72 times
Not authorised
Post by DARK STAR » Fri Aug 10, 2018 9:45 pm
Apparently I have a PM but am not allowed to access it ...
Capture d’écran 2018-08-10 à 22.43.34.png (44.69 KiB) Viewed 819 times
Been thanked: 539 times
Not authorised
Post by philhoward » Fri Aug 10, 2018 10:18 pm
Only reason I’ve come across for messages on hold is because your inbox is full?
Not authorised
Post by DARK STAR » Sat Aug 11, 2018 6:08 am
Ah possible ... should I not be advised of this?
I'll have a look.
Not authorised
Post by DARK STAR » Sat Aug 11, 2018 6:14 am
Ok, can't find how to delete messages so I have changed the settings - oldest messages deleted automatically.
Thanks Phil
Not authorised
Post by scimjim » Sat Aug 11, 2018 8:39 am
In every PM there is a set of icons in the top right corner.
X = delete
! = report
“ = quote
Not authorised
Post by DARK STAR » Sat Aug 11, 2018 11:40 am
Thanks Jim.
That could take some time to delete them all one by one 8)
Been thanked: 472 times
Not authorised
Post by Roger Pennington » Sat Aug 11, 2018 9:29 pm
Thanks Jim.
No need to do them one by one - If you go into the Inbox list page, you'll see that each message has a little box on the right. Scroll down to the bottom, and on the right hand side, there is a "mark all/unmark all" selection. hit "mark all" and all the PMs in the list will get a tick in the box. Then go to the selection drop-down just above that, and you'll find there is an option to "delete marked" - select this and press "go" and you'll delete that whole page full of PMs. :D
