How to upload a picture
Locked
erikscimitardemon
Post by erikscimitardemon » Fri Aug 10, 2007 1:59 pm
*** As of 28/6/2017, Photobucket have changed their terms and conditions to block 3rd party use (such as this forum) - we would advise NOT using photobucket at this time ***
if you Use an external site, like photobucket.
These provide the correct tags to paste into your message ('BB').
A tag should look like this:
{IMG]http://i654.photobucket.com/albums/uu26 ... GP0283.jpg[/IMG}
I made a deliberate mistake in replacing all '[' with '{' otherwise you'd see the picture below.
This is a small size clickable image to a bigger size original.
Example is the GTC picture.
you can Use a picture from the Gallery.
You can use your own pictures, or someone elses.
The Gallery is here:http://www.scimitarweb.co.uk/sgwrs/app.php/gallery a link is on any forum page in the right top corner of the pages, between 'FAQ' and 'Members'.
Choose the picture you want to use. Click on it. Now you get a big picture. In the Details section below you can copy Image URL code from the top box:
http://www.scimitarweb.co.uk/sgwrs/app. ... 387/medium
press the button that looks like a mountain in sunshine (above this text box) and you should see the "IMG" tags - like this but with normal square brackets {img][/img}
Paste the address you copied between those tags - {img]here[/img}
And you should see the picture
Erik Hofman
http://www.scimitar.demon.nl
alarmman49
Has thanked: 24 times
Re: How to upload a picture
Post by alarmman49 » Tue May 24, 2016 4:45 pm
Hi Guys,
I have uploaded a photo which I want to add to my profile but it has gone into my gallery............how do I attached it to my profile so it appears when I submit a post ?? it can be done as other people have a photo again their name so can anyone help. PS I find the website really hard to navigate/use (must be my age) !! thanks Tony.
Has thanked: 22 times
Been thanked: 83 times
Post by swoakes » Tue May 24, 2016 5:12 pm
You need to edit your signature in your profile; easiest way is to link to a photobucket image like I have below because the file size can be much bigger
Been thanked: 460 times
Post by Roger Pennington » Tue May 24, 2016 7:18 pm
Also, in the same area, you can edit your avatar image, which appears to the left of your post. This is found in User Control Panel/Profile/Edit Avatar where you can then add an image which should conform to the following requirements
Maximum dimensions; width: 80 pixels, height: 80 pixels, file size: 5.07 KiB.
Been thanked: 534 times
Post by philhoward » Fri Jun 30, 2017 8:56 am
Post by philhoward » Fri Jul 28, 2017 2:08 pm
V3.2 Post July 2017 instructions:
Drag and Drop
1. Select your picture from (in this case) my Windows Explorer window
Drag and Drop Stage 1.JPG (154.51 KiB) Viewed 1681 times
2.Drag it over to the box where you normally write your text, then let go of the mouse (Copy and Paste doesn't work - I tried it :))
Drag and Drop Stage 2.jpg (153.5 KiB) Viewed 1681 times
3.That should then show the filename in the box that will now appear below
Drag and Drop Stage 3.JPG (26.63 KiB) Viewed 1681 times
4. Click on the "Place inline" button to add it into the reply box - handy if you want to add text around it
Drag and Drop Stage 4.jpg (135.29 KiB) Viewed 1681 times
If you're unsure at any stage, see what the "Preview" button gives you.
If you miss out step 4, it will still show the pictures - but below any text and with a white border
If you don't want to drag & drop, instead of steps 1 & 2 above - simply press the "add file" button below the text box and find the picture in your files (steps 3 & 4 are the same)
photos
Post by Roger Pennington » Thu Aug 03, 2017 1:16 pm
Right, here are the screenprints of the process: (on an Android phone using Firefox)
Screenshot_Number 3.jpg (106.58 KiB) Viewed 1624 times
Screenshot Number 2.jpg (93.73 KiB) Viewed 1624 times
Screenshot Number 1.jpg (106.29 KiB) Viewed 1624 times
Screenshot_Number 4.jpg (132.83 KiB) Viewed 1624 times
Screenshot Number 5.jpg (130.46 KiB) Viewed 1624 times
Locked
