V3.2 problems
Can't register?
Has thanked: 122 times
Been thanked: 909 times
V3.2 problems
Post by scimjim » Thu Aug 10, 2017 10:33 pm
Notifications have a "mark all as read" button on the dropdown (before you go to "see all"). If you go to the "see all" page, you need to "mark all" at the bottom of the page, then "mark read".
Not sure about the PM that was there, then not there - I think I confused a notification with a PM initially but if you had both icons red, you wouldn't do that?
Has thanked: 135 times
Been thanked: 498 times
V3.2 problems
Post by Roger Pennington » Thu Aug 10, 2017 11:28 pm
One thing I've noticed is this. I get notifications for PMs. That means that when a PM arrives, I get a red "PM indicator" and a red "Notification ind.". If I click on the PM link, it takes me to my inbox, and I read the PM. Then when I return to the index page, the PM indicator has disappeared (because I've read the PM) but the notification of the PM stays in force, with a red indicator, until I go in and mark it as read, as a separate action. So it appears that PMs you've read, may still be showing up as though they were new, in your notification list.
(not sure if it's directly relevant to Peter's problem, but it's certainly a little confusing )
V3.2 problems
Post by scimjim » Fri Aug 11, 2017 8:44 am
Yes, I've turned all notifications off except reported posts. No need for PM notification on the front page if the icons are next to each other :-)
Been thanked: 90 times
V3.2 problems
Post by Coupe Racing » Fri Sep 01, 2017 5:11 pm
New point
I'm struggling to find the solution to this issue
For the life of me I can't see how to send a PM now on the new restyled site when using a mobile device
Am I missing something ?
I tap on a user name and some have the facility (just found it) and others don't so I guess it's a personal setting with the receiver
Been thanked: 579 times
V3.2 problems
Post by philhoward » Fri Sep 01, 2017 5:34 pm
Receiving PMs is an optional feature.
