April 2017 Issues
Can't register?
Geraint SabreGTCse5
Been thanked: 35 times
Re: April 2017 Issues
Post by Geraint SabreGTCse5 » Sat Apr 08, 2017 9:42 pm
any one else drop off the site after they post a message? after each of my posts today i lost connection to the site and had to log back on.
Geraint
Sabre ti, se5, GTC, 6b.......
Geraint SabreGTCse5
Post by Geraint SabreGTCse5 » Sat Apr 08, 2017 9:44 pm
did it again posting the above this was the message
This site can’t be reached
www.scimitarweb.co.uk took too long to respond.
Search Google for scimitarweb 7080 sgwrs viewtopic
ERR_CONNECTION_TIMED_OUT
Geraint
Datsundrew
Post by Datsundrew » Sat Apr 08, 2017 9:46 pm
I'm going to give up on this site soon, I can't be doing with the constant crashing an re logging in, so it's not just you!
Post by Roger Pennington » Sat Apr 08, 2017 10:09 pm
Geraint SabreGTCse5 wrote:did it again posting the above this was the message
http://www.scimitarweb.co.uk took too long to respond.
In answer to your question about "drop off the site" no, I don't. I get a timeout message as above, but that's only the page, I'm still logged-in and a simple page refresh takes me back to wherever I wanted to go - view unread, forum index, or wherever. I don't get logged-out or anything like that.
Been thanked: 842 times
Post by scimjim » Sat Apr 08, 2017 10:22 pm
Me too - sat here discussing it with Phil and it appears that my bookmark has the 7080 in it - if you type in scimitarweb.co.uk (with or without the /sgwrs to go directly to the forum) it works fine but then any reply or redirect has this 7080 which causes it to hang?
AnotherTim
Post by AnotherTim » Sat Apr 08, 2017 10:29 pm
Yes, I drop out after every post. I assumed it was just me.
About to press send so bye for now.
Been thanked: 321 times
Post by peter freeman » Sat Apr 08, 2017 10:31 pm
It has got to be something that has happened / been changed recently as I only have had the problem from today.
Post by Roger Pennington » Sat Apr 08, 2017 10:33 pm
peter freeman wrote:It has got to be something that has happened / been changed recently as I only have had the problem from today.
That's what I always say when the car goes wrong! Yes, like you, it's only been a problem for me today
Ian
Been thanked: 46 times
Post by Ian » Sun Apr 09, 2017 10:27 am
I am now about to spend a sunny Sunday behind my computer trying to resolve the issues. :evil:
The same root cause is showing up as a lot of different symptoms :w such as timeouts, double posting and smartfeed failure. Please try to report any current problems via this thread so I can keep track of things.
Ian
ScimitarWeb WebMaster
RSSOC 453
Post by peter freeman » Sun Apr 09, 2017 10:33 am
I can still use the site all be it with a bit of a fiddle so don't stay in out of the sun on my account - get it while you can.
Rattling
Post by Rattling » Sun Apr 09, 2017 10:35 am
Just double posted because it said server not responding, also when signing in / out it no longer goes to a page I have to pres forum,hope this helps !
Colin
1800 Ti
Rattling
Colin
1800 Ti
Ian
Post by Ian » Sun Apr 09, 2017 11:49 am
I've applied what I hope to be a fix for these problems. :?: It is deep in the server operating system so I'm being conservative with any changes that I make so as not to cause other issues.
NO url should have :7080 or :7081 in it!
Please make sure that any favourites, bookmarks, shortcuts etc that you have saved do not have these numbers included. If in doubt, start at the site homepage scimitarweb.co.uk/, click through and recreate your saved links as appropriate. Also for those using feeds, please regenerate your feed if there are problems.
Let me know if any issues persist and if new ones appear.
Ian
RSSOC 453
Post by scimjim » Sun Apr 09, 2017 11:58 am
Test reply - fixed for me thanks Ian :-)
Post by scimjim » Sun Apr 09, 2017 12:03 pm
And my bookmark has automatically changed back?!?
