Pistonheads - Spotted
Seen a Scimitar somewhere? Let them know and maybe make contact locally.
scimmy ben
Post by scimmy ben » Sat Dec 08, 2018 6:46 am
Dcrosby13
Been thanked: 32 times
Post by Dcrosby13 » Sat Dec 08, 2018 7:44 am
They could have picked one in a better colour to write about 😲
I break stuff...... :w
cannonball
Post by cannonball » Sat Dec 08, 2018 9:45 am
I like the the MPG and the CO2 that Piston heads state and there are more photos of this nice looking car here.
https://www.grahamwalkerltd.co.uk/relia ... er-6379472
Laters
Has thanked: 41 times
Post by Laters » Sat Dec 08, 2018 1:24 pm
I'm pretty sure that car was on ebay earlier this year.
There was certainly a car in the same colour with the same interior colour.
It was one of the ones I got outbid on when I was looking for my se6.
Paul
Geraint SabreGTCse5
Been thanked: 37 times
Post by Geraint SabreGTCse5 » Sat Dec 08, 2018 6:11 pm
thats were a lot of Mr Walkers stock comes from.....
Last edited by Geraint SabreGTCse5 on Sat Dec 08, 2018 9:37 pm, edited 1 time in total.
Geraint
Sabre ti, se5, GTC, 6b.......
Laters
Post by Laters » Sat Dec 08, 2018 7:29 pm
Looking through my older note on cars I was interested in/wanted to bid on/make offers on I know why I didn't want to bid anymore on that car.
From MOT history
22 February 2018
Fail
Mileage
84,609 miles
MOT test number
9155 4070 7325
Test location
► View test location
Reason(s) for failure
Offside Electrical wiring deteriorated and bare wires exposed (1.9.2c)
Brake pipe inadequately clipped front to rear (3.6.B.1)
Offside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3)
Nearside Rear Suspension component mounting prescribed area is excessively corroded (2.4.A.3) Dangerous
Nearside Rear Suspension component mounting prescribed area is excessively corroded side rail (2.4.A.3)
Nearside Front Upper Front suspension ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
Offside Front Upper Front suspension ball joint dust cover excessively damaged so that it no longer prevents the ingress of dirt (2.4.G.2)
Nearside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Windscreen wiper does not clear the windscreen effectively (8.2.2)
Offside Front wheel bearing rough when rotated (2.5.A.2)
rear brake application uneven (3.7.B.2)
Nearside rear parking brake recording little or no effort (3.7.B.6a) Dangerous
Offside rear parking brake recording little or no effort (3.7.B.6a) Dangerous
Front Tyre(s) incorrect because different size tyres are fitted on the same axle. 185-14 and 205/70-14 (4.1.A.1a)
Parking brake: efficiency below requirements (3.7.B.7)
Rear Brakes imbalanced across an axle Axle 2 (3.7.B.5b)
Advisory notice item(s)
Nearside Front wheel bearing has slight play (2.5.A.3c)
Nearside Front chassis rail split and not attached to side rail
Offside Front chassis rail holed and corroded
Offside Front floor holed
Offside Front door has slight drop
Offside Front water pipe insecure on inner wing
coolant pot insecure
spark plug tester still attached inline on lead O/S bank
slight wear in all front suspension bushes
I don't remember it looking as good as it does now so they have spent some time & money on it to get it looking like that.
I'm still not a fan of the interior colour scheme at all though.
Paul
Return to “Scimitar Sightings”
