SE5a stainless steel fuel tank
Locked
Tinker man
Post by Tinker man » Mon Mar 19, 2018 9:01 am
good morning all,
as you may have seen on my project update the bespoke exhaust i have manufactured means that this stainless tank, bought from a member on here last year, will no longer fit. so thought would ask on here first.
it is now surplus to requirements. its been cleaned up and so have the straps. cannot 100% vouch for the sender as i have never fitted it, but see no reason that it wont work.
i live in Davenham Cheshire and work in Stoke on Trent most of the time. i can deliver if necessary within a reasonable distance or you can collect. if required can get a reasonable price to deliver through work at your cost.
how does £75 sound?
just drop me a PM or reply to this. thanks, Ian.
fuel tank 1.jpg (99.63 KiB) Viewed 1213 times
fuel tank 4.jpg (127.18 KiB) Viewed 1213 times
fuel tank 3.jpg (93.5 KiB) Viewed 1213 times
fuel tank straps 2.jpg (167.13 KiB) Viewed 1213 times
Tinker man
Post by Tinker man » Mon Mar 19, 2018 9:03 am
one more thing... please do not judge my clinical working conditions!
pjkpjk
Post by pjkpjk » Mon Mar 19, 2018 7:55 pm
Hi, is this tank the same as the later SE6 models? cheers Peter
Been thanked: 539 times
Post by philhoward » Mon Mar 19, 2018 8:05 pm
Nope - 6-series tank is 3” wider.
pjkpjk
Post by pjkpjk » Mon Mar 19, 2018 8:19 pm
Been thanked: 472 times
Post by Roger Pennington » Mon Mar 19, 2018 8:25 pm
Also if your car is a later one (roughly, but not exactly, Se6a-on) then it will probably have the flow and return fuel system, which needs two stubs on the tank, which a 5-series tank won't have.
upstart8s
Post by upstart8s » Tue Mar 20, 2018 5:05 am
or to use Rogers' quote from some time ago (6-series tank is 3 GALLONS wider)
Stu
Mikeincoleshill
Post by Mikeincoleshill » Tue Mar 20, 2018 3:26 pm
PM'd you for this Ian.
Mike
Tinker man
Post by Tinker man » Mon Mar 26, 2018 12:17 pm
hi Gents,
now sold. thanks, Ian.
Locked
