SS1 Roll hoop bar
Cars and Parts Wanted
Turner998
SS1 Roll hoop bar
Post by Turner998 » Thu Oct 10, 2019 8:16 pm
Hi. Has anyone got a roll bar for sale. Also what is the gearbox mount from please as the sierra one I bought is different to the one that came with the type 9 5 speed mounting I have acquired for conversion.
Thanks in advance. Craig.
Has thanked: 78 times
Been thanked: 707 times
SS1 Roll hoop bar
Post by philhoward » Thu Oct 10, 2019 8:46 pm
The actual metal/rubber mount should be the same although they were riveted to the metalwork on the Sierra I think. The metal bit between the mount and chassis is SS1 specific (not shared with a Ford) and also differs between 4 and 5 speed gearboxes.
I think I’ve understood your question correctly but happy to be guided with a picture if I’ve got it wrong.
Has thanked: 102 times
Been thanked: 153 times
SS1 Roll hoop bar
Post by reliant-reviver » Thu Oct 10, 2019 9:13 pm
Cortina rather than Sierra.
Barry Cunningham has a roll bar for sale in eBay ATM
Turner998
SS1 Roll hoop bar
Post by Turner998 » Thu Oct 10, 2019 9:19 pm
Thanks Phil. The mounting plate for 5 speed I have as came with type 9 from a ss1 from a good person here. The mounting I refer is the rubber/ metalistic mounting with single centre bolt I to gearbox. The mounting that came with the box had a flat bottom to sit onto ss1 plate. The one from fleabay is not flush mounting i.e. The 2holes to bolt to the mounting plate have a step up, so box will be about 10mms higher. A picture would explain.
Turner998
SS1 Roll hoop bar
Post by Turner998 » Thu Oct 10, 2019 9:26 pm
Thanks Phil and phil. Looked now and can see diference, so question answered. Anybody
E.g. Need sierra box mount 😢 have seen the bar on ebay.
, But does not look like club one, or am I not seeing as does not appear to have arms to side b posts?
Both. Thanks.
SS1 Roll hoop bar
Post by reliant-reviver » Fri Oct 11, 2019 11:57 am
Not a Reliant / "club" design of bar.
I have had this type before and I believe they were manufactured by Alleybars (sp?)
Arguably not as strong as only located by the base plate and not tied into the B pillar.
SS1 Roll hoop bar
Post by philhoward » Fri Oct 11, 2019 11:59 am
In that case, Cortina/Escort as eluded to by reliant-reviver.
Return to “Wanted”
