Brake master cylinder SE4 or SE5
Cars and Parts Wanted
Moderators: scimjim, philhoward, Lukeyboy46, erikscimitardemon, Roger Pennington, Terry Rickard
roymck
Has thanked: 15 times
Been thanked: 24 times
Post by roymck » Sun Apr 14, 2019 7:06 pm
Looking for a original style large reservoir Girling 7/8 brake master cylinder in new condition Or good used condition that I can rebuild . I have so far tried 2 different make of pattern cylinders and both are rubbish. Just need to get my brakes sorted .
David Tew
Post by David Tew » Mon Apr 15, 2019 2:51 pm
Hi Roy,
No doubt you've seen this one. A bit pricey though and it's badged Lucas so it's not period NOS.
Are your cylinders so bad they can't be reconditioned? I've usually managed to recover even apparently scrap cylinders by careful dismantling, cleaning and honing.
Been thanked: 616 times
Post by philhoward » Mon Apr 15, 2019 2:54 pm
Do you want one with the integrated reservoir or the separate plastic one?
I think I’ve got one of each but would need to dismantle then to check the state of the bore.
roymck
Post by roymck » Mon Apr 15, 2019 4:50 pm
David , good spot but a pricey option ,Sunbeam tiger tax included .
Phil , would prefer a integrated cylinder version if you have one , I have a pattern version with a plastic reservoir and just cannot stopping it weeping . Is the non integrated a Girling ? Let me know please .
Thanks Roy
Post by philhoward » Mon Apr 15, 2019 4:56 pm
I'll have a dig around when I pop into the garage. I believe they are all original Girling units but it's a while since I've studied them!
roymck
Post by roymck » Mon Apr 15, 2019 6:48 pm
Yes please Phil when you can
Landy109s2a
Post by Landy109s2a » Tue Apr 16, 2019 8:10 pm
Original "GIRLING 875 Brake Master Cylinder" available. All taken apart, cleaned and ready for rebuild.It was a spare for my SE5. Car sold, so not required. I have a New set of seals to go with it. £25. Including P&P. "Unit Sold"
roymck
Post by roymck » Tue Apr 16, 2019 11:03 pm
Sounds good for me . Will send PM in the morning
Return to “Wanted”
