Trailing arms ss1turbo
Cars and Parts Wanted
Moderators: scimjim, philhoward, Lukeyboy46, erikscimitardemon, Roger Pennington, Terry Rickard
hermeticist
Post by hermeticist » Sun Mar 17, 2019 1:47 pm
That was exactly my thinking, although, I suspect, there will be some people who want to keep (the look of) originality. RHS (square section tubing) is slightly heavier for the same size section, due to the extra material, but is torsionally stronger and has a greater deflection factor (particularly when a spine is parallel to the deflection load - so probably in direct line with the arc of movement). Obviously, the weight can be reduced by material selection and the best outcome would be: decreased weight (although this will affect spring/damper), increased rigidity (removing unwanted suspension flex and potential changes in geometry) and increased strength. This isn't necessarily unobtainable because, as we know, Reliant are making parts to a price. However, we also need to factor this into the design. I'm not concerned about being able to improve on the original but I will have to investigate the insurance, because I would be supplying a very critical part of a (relatively) complex system. My insurance probably doesn't cover the manufacturing of car parts. If anyone from the club has any knowledge of this I would be pleased to accept advice.
Has thanked: 86 times
Been thanked: 132 times
Post by reliant-reviver » Sun Mar 17, 2019 2:50 pm
Be lovely to see them made with an adjustable inner mount as per the TVR S3 to allow for setup of camber and toe.
As for immediate supply of trailing arms, I have several sets spare available, although not at a give-away price.
hermeticist
Post by hermeticist » Sun Mar 17, 2019 6:18 pm
This is good, if I can mock up a design from the original and then people with experience of racing, modifying and/or working on the cars can feed in, we could have a top quality product. Maybe we can then also find a suitable droplink replacement or at least make the arm ready to take a different link? Jim, or anyone else, I'd still like to copy the hood stiffeners though :)
Dcrosby13
Been thanked: 32 times
Post by Dcrosby13 » Sun Mar 17, 2019 6:27 pm
I believe alternative drop links have already been sourced from a BMW? From memory I think it was a 3 series
I break stuff...... :w
Has thanked: 50 times
Been thanked: 589 times
Post by philhoward » Sun Mar 17, 2019 7:37 pm
5 series but I think Corky has found a more suitable candidate since?
Has thanked: 129 times
Been thanked: 938 times
Post by scimjim » Sun Mar 17, 2019 8:01 pm
The BMW ones (and I think most others) need modifications to the thread to fit. It would be good to pick a modern car that we might find replacements for in years to come, and fit that thread?
I found the hood stiffeners and a dead trailing arm - who’s passing Gloucester on their way to Plymouth in the near future? Mikey MikeyBikey, Josh Oaksey?
hermeticist
Post by hermeticist » Mon Mar 18, 2019 3:00 am
Thank you Jim! With regards to the drop links, it seems to make sense that if we remake a trailing arm it allows direct fitment without the end user needing to make any adjustment. Obviously the other end may require helicoils but at least one end will be ready to go.
Has thanked: 229 times
Been thanked: 112 times
Post by MikeyBikey » Tue Mar 19, 2019 6:43 am
I’m in Somerset at the weekend ?
Has thanked: 30 times
Post by Alan SS1 » Sun Mar 24, 2019 8:17 pm
i can send you measuremnets in autcad format, also i started working on the design on a free 3D drawing package, called OnShape, search for Reliant SS1 rear arm and it should appear, 'should' and you are welcome to use as a starting point.
OnShape is free to use IF you are willing to have the drawings avialble to others, the owner keeps the original version bu tothers can copy/edit as they wish
Has thanked: 185 times
Been thanked: 183 times
Post by Corky » Sun Mar 24, 2019 8:23 pm
Yes, I’ve found some with the correct M12 1.75 thread. Not actually tried any on the car yet though.
Post by scimjim » Sun Mar 24, 2019 8:27 pm
M12 both ends? Details please :D
Post by Corky » Sun Mar 24, 2019 9:37 pm
Some of my findings are here http://www.scimitarweb.co.uk/sgwrs/view ... 0&p=464983 , but I’m sure I found a few more. They’re probably in my eBay watch list, I’ll have a look.
Post by Corky » Sun Mar 24, 2019 9:57 pm
Post by scimjim » Sun Mar 24, 2019 10:10 pm
Just posted in the other thread - ordered a set of the Jag fronts. How long are the originals?
Post by Corky » Sun Mar 24, 2019 10:16 pm
iirc 95mm between bolt centres, but I don’t have any to hand that I can check.
Return to “Wanted”
