SE5a battery positive cable
Cars and Parts Wanted
Has thanked: 104 times
Been thanked: 21 times
Post by willholderogri » Fri Sep 21, 2018 7:49 am
See attached pic if you look in the middle of the photo you can see where the old lucar connections are soldered to the new box. you have to remove a small amount of the outer box to do this.
The plus point is the whole assembly is bolted to the car and the terminals are removable by taking the outer cover off.
I did this in 2005 so its a bit dirty now (car used every day not problems ) .
Post by willholderogri » Fri Sep 21, 2018 7:50 am
picture seems to have disappeared will try again
Post by willholderogri » Fri Sep 21, 2018 7:51 am
is it there
Post by willholderogri » Fri Sep 21, 2018 7:52 am
Sorry the pic will not load if you want to send me your email and I can send it direct .
Post by willholderogri » Sat Sep 22, 2018 8:02 am
Anybody able to upload my photo or can it be done some other way
Been thanked: 534 times
Post by philhoward » Sat Sep 22, 2018 8:08 am
You need to wait for this to appear:
Then you can submit the post - use the “Place Inline” option, then “Preview” to check.
Post by willholderogri » Sat Sep 22, 2018 8:26 am
Picture of my modification
Post by willholderogri » Sat Sep 22, 2018 11:57 am
Ok I give up it will not load no Matter what I do
scmarf
Post by scmarf » Sat Sep 22, 2018 12:14 pm
Geraint.
Just checked and the positive cable in your photo is for a SE6a(b?SE8?) but it is probably - if anything - longer than the SE5a so still interested in purchase if available.
Will,
PM sent.
Honda Jazz
Been thanked: 840 times
Post by scimjim » Sat Sep 22, 2018 12:42 pm
Email it to me - could be your internet connection?
Post by willholderogri » Sat Sep 22, 2018 2:06 pm
Thanks have emailed it to Phil
Post by philhoward » Sat Sep 22, 2018 2:20 pm
It did take a while to upload to the forum (and I’m on 4G) by the way - you might not have given it sufficient time?
Post by willholderogri » Sat Sep 22, 2018 3:40 pm
Thank you I will remember in future
Return to “Wanted”
