Essex Engine for a 1980 GTE
Cars and Parts Wanted
swiv
Post by swiv » Thu Nov 16, 2017 12:21 am
Hello, I'm hunting for an engine to ressurect my 1980 GTE..
It's been a money pit so far.. I've had the heads done but boils up and blows steam through the rocker cover, so rather than attempt to patch up the existing engine, I'm looking for another lump.. Then I can strip the existing engine at my leisure..
Lee
Post by Lee » Thu Nov 16, 2017 9:44 am
I have one that was removed from a 1980 GTE. The core plugs will need replacing and I have never heard it running, but it does turn over by hand. It might help you out.
"Obviously your ambition outweighed your talent"
Been thanked: 193 times
Post by AJL Electronics » Thu Nov 16, 2017 9:59 am
It may be quicker to replace the inlet manifold gasket, than to swap the engine out.
Has thanked: 34 times
Been thanked: 436 times
Post by philhoward » Thu Nov 16, 2017 10:06 am
Perhaps the heads have been skimmed a bit too much? If so, the inlet manifold needs machining to match as the shape of the vee it sits in has effectively changed.
Have you tried checking the torque on the inlet manifold bolts? They are known to settle after running for the first few times.
SS1's - 1600 Rooster Turbo; Sabre Mk1.5
swiv
Post by swiv » Sat Nov 18, 2017 4:39 am
Thanks Phil, that's a good spot.. I will have a look but since my 'incident' I haven't dared to stick my face under the bonnet since it rather explosively boiled up on me.. I suffered minor burns but enough to get a DIY face peel..
swiv
Post by swiv » Sat Nov 18, 2017 4:42 am
Thanks Lee.. That sounds superb. I've dropped you an email..
Lee
Post by Lee » Sat Nov 18, 2017 10:22 am
Hi, I don't seem to have received an email, PM as of yet.
swiv
Post by swiv » Sat Nov 18, 2017 12:29 pm
Hmm.. I clicked on the ''Contact" on the left hand side.. I'll give it another go..
Lee
Post by Lee » Sat Nov 18, 2017 3:44 pm
Nope. Still nothing.
Colinsw1
Post by Colinsw1 » Sun Nov 26, 2017 6:14 am
I've just listed a really nice, complete, Essex engine on here. Runs beautifully. Absolutely everything with it - turnkey unit.
Return to “Wanted”
