Se6b front shock absorbers wanted
metalmoth
Post by metalmoth » Sun Oct 29, 2017 10:51 am
Se6b front shock absorbers wanted as mine are seized. Are they the same as Se5 ones?
1982 SE6b factory black aka The Beast
What could possibly go wrong?
rebel alliance
Been thanked: 37 times
Post by rebel alliance » Sun Oct 29, 2017 11:49 am
No bigger...bit off topic was that you with the black 6b at tangmere ?
Geraint SabreGTCse5
Been thanked: 34 times
Post by Geraint SabreGTCse5 » Sun Oct 29, 2017 12:19 pm
I bought a new set of adjustables from GW, and tried them on my 5 and GTC with no issues i don't think there is a size difference on the front ones.
may depend on the make
Geraint
Sabre ti, se5, GTC, 6b.......
Has thanked: 113 times
Been thanked: 823 times
Post by scimjim » Sun Oct 29, 2017 12:33 pm
Shocks are possibly the same, as ride height is controlled by spring length - the shock is unlikely to hit either end stop with either spring (5 series/6 series) fitted. As long as the eye ends are the same size.
Been thanked: 77 times
Post by gtcse8 » Sun Oct 29, 2017 1:49 pm
As Jim says, they are interchangeable on the fronts, the spring, that holds the ride height up, WILL go coilbound before you fully compress the damper unless you have some special springs made/fitted.
Also as Geraint says MOST shocker sets will fit MOST models, AFAIK the only specific shocker for a model is the MONROE GASMATIC, these were introduced for the FRONT of SE6/A models due to the factory spring being too soft.
Some "Complete" units used 14" springs on the rear sets, and some 13" so be wary when mixing dampers and springs.
metalmoth
Post by metalmoth » Sun Oct 29, 2017 2:55 pm
My springs are ok so could be fitted to the 5a shocks . I'm only asking as there are some on eBay and I don't want the expense of new adjustable coilovers just yet as have other jobs to do.
PS yes that was me in tangmere, what were you in then rebel?
rebel alliance
Post by rebel alliance » Sun Oct 29, 2017 3:15 pm
Ah yes we had a chat the cream 6a ,nice to have met you.j
metalmoth
Post by metalmoth » Sun Oct 29, 2017 7:38 pm
Hi yes i remember now. Nice to have met you too
metalmoth
Post by metalmoth » Sun Oct 29, 2017 10:17 pm
So then has anyone got some?
Post by gtcse8 » Sun Oct 29, 2017 10:19 pm
Thought you were getting 5a dampers and swapping the springs?????
Lee
Been thanked: 11 times
Post by Lee » Mon Oct 30, 2017 11:01 am
I have some. They are rough looking though.
"Obviously your ambition outweighed your talent"
Has thanked: 41 times
Been thanked: 208 times
Post by AJL Electronics » Mon Oct 30, 2017 11:55 am
I am a Spax dealer, so can supply new ones if you wish?
metalmoth
Post by metalmoth » Mon Oct 30, 2017 1:50 pm
I've been looking at the parts diagrams on GW and it appears that all models have different part numbers for front shocks so I could be throwing money away
Post by scimjim » Mon Oct 30, 2017 2:27 pm
Originally they would have but over the years I think the aftermarket replacements have converged to reduce the number of dampers required. Same has happened with springs, where I think the only ones supplied by the traders now, are what used to be called “uprated”.
metalmoth
Post by metalmoth » Mon Oct 30, 2017 2:32 pm
Ok thanks
Locked
