Manual Gearbox Conversion Kit £350 East Sussex
Parts for Sale
nutgone
Has thanked: 59 times
Post by nutgone » Tue Feb 18, 2020 6:37 pm
Having sold my Scim some time ago (& in need of some cash for some workshop machinery) it's time to sell the manual conversion parts I bought for the car.
Included are the following:
2-rod, 4 speed + O/D box, complete with slave cylinder & clutch arm.
Rear gearbox mount cross member (still attached to box),
Prop shaft,
Pedal assembly,
later type flywheel,
One good master cylinder (brake & clutch are same size on this setup),
brand new stainless steel braided clutch hose,
brand new pilot bearing,
brand new release bearing (to suit later flywheel assembly, the bearing mount has been machined to fit & bearing is fitted ready),
Brand new clutch kit (still in box),
Brand new "OVERDRIVE" badge for back of car,
universal leather gearstick gaiter (black).
Parts I've lost but may well turn up:-
Return spring for pedal assembly (both clutch & brake pedals take the same springs, one was broken but I seem to have lost the good one)
brand new "8-Ball" gear knob, threaded to fit gear stick.
Some parts have been stored outside, so it'll all need cleaning up & checking.
I removed the overdrive inhibitor switch (these are very expensive new, if you can find one), rebuilt it & stored it inside, so that's OK.
It's basically an almost complete kit of parts to convert your scimitar to manual. All you'll need is some wiring bits for the overdrive, plus an overdrive switch, & some bits & bobs like a piece of brake pipe (although I have a roll so could even throw in a bit of that).
This lot cost me a small fortune to put together, but I need it gone. so I'm taking a loss at £350 (no offers).
I can strap it to a pallet for a small fee, but you'll have to arrange a courier.
Please either call/text/WhatsApp me on 07412389270 (you'll probably have to leave a message if calling, so may be better to text first) or email me through the forum.
I'm sure there are bits I've forgotten, so I'll edit this as stuff turns up.
Located in East Sussex, near Eastbourne (BN27 postcode)
nutgone
Post by nutgone » Sun May 03, 2020 3:41 pm
Still for sale, & can be pallet transported
Johniewalshe
Post by Johniewalshe » Thu Jun 04, 2020 4:04 pm
Which model are the parts for, se5 or 6 thanks
Has thanked: 74 times
Been thanked: 102 times
Post by Oldconn » Thu Jun 04, 2020 4:52 pm
He says the brake & clutch master cylinders are the same size, so it wasn't intended for a SE6
Has thanked: 167 times
Been thanked: 1178 times
Post by scimjim » Thu Jun 04, 2020 5:16 pm
A 2 rod box would be from a 5/5a but they have been fitted to a 6 before.
Post by Oldconn » Thu Jun 04, 2020 7:33 pm
Yes, Mine for example! However, the comment about hydraulic cylinders confuses me. Didn't the SE5A have vacuum-assisted brakes? How canthe master cylinders be the same size?
rebel alliance
Been thanked: 90 times
Post by rebel alliance » Thu Jun 04, 2020 7:46 pm
Remote servo.
Post by scimjim » Thu Jun 04, 2020 7:52 pm
I have the same size (Non-original) brake and clutch master cylinders on 8ball.
Return to “Parts For Sale”
