New V6 (Essex) ALLOY cam timing gear sets
Parts for Sale
Has thanked: 109 times
Been thanked: 161 times
Post by reliant-reviver » Wed Sep 04, 2019 10:32 am
Physically in stock and ready to dispatch.
ED 16/04 I have revised pricing in respect to certain factors since last year.
£160.00 plus delivery which is £7.90 (per shipment) to mainland UK destinations and as advised to all other locations and countries.
Offered to existing forum members and current RSSOC members on a first come first served basis before they will be made available to the wider masses at a more usual (higher) price.
Each set includes :
1 x Alloy camshaft timing gear wheel
1 x Steel crankshaft gear sprocket
1 x Timing case oil seal
1 x Gasket set for timing case
1 x Roll pin to fit fuel pump drive wheel
Supplied as a complete kit to enable full installation to be carried out either with the engine in situe or during the course of a fuller rebuild.
The risks and failures of the original equipment "fibre" and "nylon" timing wheels are well documented. A partial or complete failure of the timing gear causes the valve timing to be disrupted usually resulting in major engine failure from valves and pistons making contact.
Steel timing gears have for a long time been available but have their own drawbacks with greatly increased gear noise often being characteristic and this is often found to be unacceptably loud for many road users. There is also the possibility on tuned and high revving motors that at very high RPM engine speeds the combination of steel timing gear and steel crank gear can cause the camshaft to fracture.
This kit provides what could be deemed the best alternative to the OE arrangement. With a complete one piece alloy timing gear and matched replacement steel crank gear. The combination of steel and alloy gears contacting through helical cut teeth results in a much quieter working assembly.
Please contact me via PM (private message) to arrange purchase.
SS TGV6 01 WM.jpg (71.9 KiB) Viewed 2569 times
SS TGV6 02 WM.jpg (124.51 KiB) Viewed 2569 times
SS TGV6 04 WM.jpg (61.07 KiB) Viewed 2569 times
SS TGV6 05 WM.jpg (96.03 KiB) Viewed 2569 times
Last edited by reliant-reviver on Mon May 04, 2020 2:12 pm, edited 4 times in total.
MrGoldtop1960
Has thanked: 28 times
Been thanked: 26 times
Post by MrGoldtop1960 » Wed Sep 04, 2019 12:32 pm
Hi Phil,
Glad to see the new batch have arrived!
As a footnote to installation, it may be prudent to have a spare sump gasket to hand as the front timing cover sits on the front section of the sump pan and when you remove the front timing cover it may (most likely!) destroy the sump gasket :(
Kev
Kev Osborne
Solent Noggin NogSec.
Member No.2104
Post by reliant-reviver » Wed Sep 04, 2019 12:44 pm
Good point and duly noted. Shall investigate and see if I can look to stock and offer those also.
The GTE's are a slight step out of my usual territory really, it's only through a sort of wandering progression that I have ended up taking these on board. Hopefully though it serves as the first step in offering a few more Scimitar components through my existing retail business, we shall see where it leads!
Now on eBay also, got itchy fingers and launched the listing earlier. Priority will be given to those on the forum / in the club however and the price is of course much better here than via our favourite online trading platform with their fees.
Has thanked: 178 times
Been thanked: 1226 times
Post by scimjim » Wed Sep 04, 2019 12:59 pm
Tidied up the How To Guide on changing the camwheel and added gaskets
Steve_S
Post by Steve_S » Thu Sep 05, 2019 4:37 pm
Hello
Can I get One of these ?
Post by reliant-reviver » Thu Sep 05, 2019 5:07 pm
Yes send me a PM (private message) and I'll come back to you.
Do excuse the convoluted contact route, but there is method to my madness and it is so I can keep track of whom on here is contacting me and benefiting from the lower price I have offered here.
I shall launch a new website / webshop at a later date to simplify things. But until then the to and fro method is best.
rebel alliance
Been thanked: 97 times
Post by rebel alliance » Thu Sep 05, 2019 6:18 pm
Sent you an email 😊
Been thanked: 842 times
Post by philhoward » Thu Sep 05, 2019 6:30 pm
Sent you an email 😊
There’s always one..
rebel alliance
Post by rebel alliance » Thu Sep 05, 2019 7:00 pm
I like to be different besides i was busy removing my front exhaust boxes to get another 30 bhp...
Post by reliant-reviver » Thu Sep 05, 2019 9:06 pm
And found in my personal spam box. Not sure why it's being over zealous.
Reply on it's way.
Post by reliant-reviver » Fri Sep 27, 2019 9:24 am
Quick post to say there are still plenty of kits available. I think I've offered to and "served" everyone who had expressed previous interest now, so it's first come first serve at the price advertised here for direct purchases from club and forum members.
FossilFish
Has thanked: 54 times
Post by FossilFish » Sat Sep 28, 2019 12:31 pm
I may need a kit. Just need to check my car if it has one (I'm sure it doesn't) I hope it stops raining so I can check.
Will be in touch soon.
Regards Raz
Thank fossils for fuel!
Post by scimjim » Thu Apr 16, 2020 7:32 pm
Bump before it drops off in the next cull - pretty sure Phil has some of these left?
Post by reliant-reviver » Thu Apr 16, 2020 7:48 pm
Yes and still happy to supply club members and forum users at a lower price than elsewhere
Stuart Robinson
Post by Stuart Robinson » Thu Apr 16, 2020 8:39 pm
Have pm'd you re cam timing gear.
1979 SE 6A
RSSOC 6406
Return to “Parts For Sale”
