GTE SE 5/5A parts and bits
GeoffTE
Been thanked: 26 times
Post by GeoffTE » Fri Aug 10, 2018 10:25 am
Need to have a clear out (she says :roll: ) so the following are going, either to those in need or to the dump. Don't know if the things that are supposed to work actually work, but they won't be expensive or maybe free. Able to bring to Curbs, but not keen on posting. Send your rep if you're not going yourself :lol:
2 x rear side windows, chrome average but can be reversed £5
2 x front L and R bumpers, chrome good no rust, but very slight damage around one bolt hole. Won't be seen when fitted £30
2 x front springs, stiffer and shorter than standard 250lb x 12", (standard 200/14) only done 500 miles. I fitted them to SAR originally but car then too low to clear bump on drive. Cost new £30 each. £20 pair
2 x Spax gas front dampers, don't look too good, but worked ok £5
Fuel pump glass type unknown working condition £2
Gauges, black rims: 2 x oil, amps, fuel, small clock, temp, all free, 3 x rev counter (don't ask!)£2 ea. can't verify that they work
2 x SE5/Coupe lower dash panel, carries wiper and heater knobs etc,, some knobs and ashtray still fitted -free
Indicator/ horn switch with cables still connected £3
Weber carb, 38 DGAS with fitted auto choke, needs thorough clean £30
2 x carb emission pipes with valves (really annoying as Ive just bought a new valve :evil: ) £1 ea
Carb spacer block with fitted 'W' , broken connector pipe but could be fixed , free
Auto gear T-bar handle , free
2x No plate light, one chrome slight damage, one black plastic, free
Interior mirror, not sure its original fitment, free
SS fuel tank restraining straps £2
Wiper motor , unknown working free
2 x original cast iron exhaust manifolds (1 with broken stud inside) free
Rear hatch, glass good, chrome poor and frame needs joining pieces £2
2 x original door tread plates, grid pattern, worn £2
Bonnet front catch and spring £2
Gear knob , free
Window winder, good, £2
Pair non standard radio speakers, free
3 x Front indicator bodies(no lenses) free
2x SE 5 rear reversing light lenses and chrome surrounds, poor. free
Loads of other bits not worth listing
Need to know if you're interested before I leave for Curbs first thing Friday
Open to offers
Geoff. (5324)
Has thanked: 79 times
Been thanked: 122 times
Post by reliant-reviver » Fri Aug 10, 2018 10:51 am
What is the ID on the front springs, 2.25" or 2.5"?
GeoffTE
Post by GeoffTE » Fri Aug 10, 2018 11:20 am
Springs are 2.5" ID
Geoff. (5324)
Has thanked: 120 times
Been thanked: 888 times
Post by scimjim » Fri Aug 10, 2018 2:11 pm
Could I have the following please Geoff?
1 x rev counter
GeoffTE
Post by GeoffTE » Fri Aug 10, 2018 2:22 pm
Yours Jim
Geoff. (5324)
GeoffTE
Post by GeoffTE » Fri Aug 10, 2018 4:18 pm
Just noticed that one of the rev counters is a speedo :oops: so one rev counter and one speedo available at £2 ea
Also part door lock/latch, the part on the body, driver's door
Geoff. (5324)
red rocket
Been thanked: 11 times
Post by red rocket » Fri Aug 10, 2018 10:16 pm
Geoff - I’ll have the dgas carb please and the wiper motor and auto shifter. Will be at Curbs. Thanks. Trevor
I only ride 'em - I dunno what makes them work
GeoffTE
Post by GeoffTE » Sat Aug 11, 2018 9:00 am
OK Trevor,thanks. See you at Curbs, look for my 5 SAR
Geoff. (5324)
GeoffTE
Post by GeoffTE » Sat Aug 11, 2018 10:47 am
I also have a complete 5/5A workshop manual copy in 4 separate ring binders with each page in its own clear plastic cover. Great condition and only a tenner and I'll throw in a copy of the Practical Classics booklet Scimitar Restoration :D
Geoff. (5324)
Benc
Been thanked: 23 times
Post by Benc » Sat Aug 11, 2018 8:00 pm
I’ll take the manual please Geoff
GeoffTE
Post by GeoffTE » Sat Aug 11, 2018 9:15 pm
Righto, see you at Curbs?
Geoff. (5324)
Benc
Post by Benc » Sat Aug 11, 2018 9:28 pm
Hi yes collect from Curbs I’ll be driving in the sprint gold & Black ss1 will be there from lunchtime Saturday I’ll find you. Thanks
scimrick
Post by scimrick » Sun Aug 12, 2018 6:31 pm
Geoff
PM just sent to you
Richard
GeoffTE
Post by GeoffTE » Mon Aug 13, 2018 11:33 am
Final call :lol:
I also have a large number (well over 100) of copies of Slice, the earliest I think is no 65, but I haven't gone through them all. There's also a technical index that covers nos 1 to 185. All Free.
Oh and there's 8 of the blue hardback binders to keep them in :wink:
Geoff. (5324)
Post by Old and Slow » Mon Aug 13, 2018 1:11 pm
Hi Geoff,
If you still have the other rev counter please put my name on it, thanks.
Philip
Locked
