Ben's (an emotional quandry) 1975 SE5a
halfpenny
Post by halfpenny » Sat May 12, 2018 7:22 am
The bottom ones are like my Lucas aux lamp mountings.
scmarf
Post by scmarf » Sat May 12, 2018 6:52 pm
Thanks both. I'm thinking maybe something like ....
bracket arrangement?
Honda Jazz
halfpenny
Post by halfpenny » Sat May 12, 2018 9:26 pm
Looks right.. I know the shape cunnigly gives just enough room to swing an open ended spanner through 65ish degrees so you can do up the bumper bracket nut, but it's a tight squeeze. Unfortunately I cannot get at my car just now. I don't have the small bits, but they may have been lost.
scmarf
Post by scmarf » Sun May 13, 2018 12:38 am
The main thing is I now know the assembly sequence:
1) Install bumpers and over riders to body.
2) Install front cross-member to bumpers and over riders.
3) Install front side panels and attach wiring.
4) Install grill.
5) Install headlights.
6) Install engine.
7) Install radiator.
8) Weld rear diagonals.
9) Attach exhausts.
10) Buy a ticket for Scimfest to help celebrate 50th anniversary of the GTE.
Honda Jazz
scmarf
Post by scmarf » Sat Jul 21, 2018 3:04 pm
Well it seems there should have been a 2.1 and 2.2 in the above list: 2.1 When replacing the headlight, I realised it was in need of some TLC so it was dismantled, wire-brushed, rust converted and painted before replacement - and then - obviously - you don't just do one do you?! 2.2 Tidying up the wiring in the engine bay is a lot easier without the engine in the way. I have now almost finished the investigation stage (checking wiring diagram in book, drawing a mini diagram for the front wiring, cleaning exposed wires so colour codes are visible and un-looming as required. Conclusions so far:
  • The relay at the front is for the air-horns, not cooling fan as I had assumed (fan circuit is standard).
  • In line fuse at front is for air horns.
  • Spot/fog light colour code is non-standard because it is retro-fitted.
The fog/spot relay case is broken (see photo) so I would like to replace it in a more suitable place. :?: Here is a question: :?:
Where does the standard SE5a spot/fog light relay go?
Wiring front
wiring front 1.JPG (187.21 KiB) Viewed 1690 times
Spot/fog relay
wiring ns 1.JPG (199.45 KiB) Viewed 1690 times
Honda Jazz
scmarf
Post by scmarf » Sun Jul 22, 2018 10:05 pm
OK. No response about the relay position. Let's try another question:
Whilst trying to work out the best plan for tidying up the front loom, I noticed:
  • the earth ring terminals (see photo 'front wiring' above) are too small for the fastener on the right side of the new crossmember
  • I could not locate a home for the rusty P clip in the centre of the loom (see centre of picture 'front wiring')
It then occured to me perhaps the loom is routed across the top of the nosecone? However I still could not identify a fastening point for the P clip. Does anyone know or have a photo of the inside of a standard SE5a nosecone showing the wiring?
Honda Jazz
Has thanked: 58 times
Been thanked: 624 times
Post by philhoward » Sun Jul 22, 2018 10:20 pm
I re-loomed mine, so don’t know where it all went originally.
scmarf
Post by scmarf » Mon Jul 23, 2018 4:53 pm
I'll have a look in the front of the SE6a and see if I get any clues.
Honda Jazz
Rev Light
Been thanked: 30 times
Post by Rev Light » Tue Jul 24, 2018 8:20 pm
I'd try and get rid of those horrible blue chock blocks , if you can, as well.
SE5a 'Fancier'
scmarf
Post by scmarf » Thu Jul 26, 2018 9:20 pm
On it Rev! :wink:
The wiring I can work out but why the hell do the earth loop terminals not fit the captive bolt hole in the front crossmember and where did the P clip go?
Honda Jazz
Has thanked: 139 times
Been thanked: 986 times
Post by scimjim » Thu Jul 26, 2018 9:38 pm
Do the Earth rings attach behind the horns?
scmarf
Post by scmarf » Mon Aug 06, 2018 12:56 pm
Interesting. This car has air horns and the standard horns are missing. Perhaps that explains it.
I got my friends Holmes and Watson around to sort out the 'P' clip:
'I can't see where the clip can go Holmes'
'I've told you before Watson, you're looking with your eyes but not seeing with your mind. Try again. What do you SEE man'
'But there's nothing there but a bit of old paper stuck to the inside of the fiberglass - no idea why'
'Ah! now continue. Your brain has given you a clue'
'By jove Holmes - you're right! Its not paper at all - its looming tape! But that puts the loom just below the central grill screw - and judging by the rust mark in the loom it puts the 'P' clip .... exactly at the scene of the crime! It must have fled from the back of the screw!'
Shall I give up the day job? :D :(
Honda Jazz
Post by philhoward » Mon Aug 06, 2018 1:15 pm
New business venture?
scmarf
Post by scmarf » Thu Sep 27, 2018 9:20 pm
You know what they say: 'If it ain’t broke ....' Well guess who thought it would be a neat touch to swap out the auto servo spout (with its tapping to the gearbox which is blanked off with a length of tube with a bolt in the end), and put in a nice manual one as it's all apart anyway. Steve Dennison came through with a nice manual spout at the last noggin so it was a simple job to unscrew the auto one and screw in the manual one. The photo illustrates the result of this naive assumption :hand: . After the purchase of a 1/4BSP tap, all is well and I am chastised.
servo spout
servo spout.JPG (88.38 KiB) Viewed 869 times
In other news, the inconvenience of having to earn a living is steadily becoming a distant memory. I thought this would accelerate the garage projects but so far this has not been the case. However, today was good. I just had to oil a patio table to keep SWMBO sweet and I got a garage pass for the rest of the day so I trimmed the edges of the head gaskets and assembled the aforementioned inlet manifold and finished off by trimming the inlet manifold gasket edges ready for the rocker covers.
headgasket
headgasket trim.JPG (78.56 KiB) Viewed 869 times
inlet gasket
Another day and most of the engine should be back together. :D
Honda Jazz
scmarf
Post by scmarf » Sun Oct 21, 2018 7:44 pm
Well here I am again :) . So what has happened since the last post? Well, putting aside 11 days in Mallorca :D 8) , I have spent quite a long time trying to work out the minor hose plumbing arrangement. Guess what, it was bodged :roll: . The confusion was partly my own fault: I broke the second rule of classic car restoration and threw away the old water pump before completely fitting the replacement :roll: :doh: . I did not notice it was obviously an SE6 pump with the top inlet blanked in the casting so the lower suction hose going to the back of the pump went to a tee piece with hoses to both the heater and the choke. So, I brought it back to standard configuration: A phone call to Nigel at QRG got me a new choke/pump hose and everything else was available from my stock. One modification was done to step down from the 18mm diameter spout out of the back of the pump to a 15mm copper tube to better fit the 13mm diameter hose. I used a bit of 16mm diameter silicone hose - see photo.
reducer
I hope the new silicone hoses now on offer take account of this reduction as the old rubber hoses didn't seem to. :?:
Now a couple of questions to you knowledgeable chaps:
1) Anybody know where this clip goes?
clip
2) The new choke to pump hose seems to interfere with the natural path for the throttle cable. I'm not keen on anything that could interfere with the operation of the cable leading to - in worst case - sticking open :shock: . Is this normal/OK?
throttle
TTFN
Honda Jazz
