The "Mighty" SE6 - New Year, New Plans
demonbluedays
Has thanked: 21 times
Been thanked: 14 times
Post by demonbluedays » Mon Aug 19, 2019 12:23 pm
philhoward wrote:
Mon Aug 19, 2019 12:08 pm
One you should know about..
:lol:
Contact block!
Key goes around fine for the first two turns (going in is never a problem, as any key of the same profile *that's also cut to a pattern* will go in no problem.) Right...off with the cowling
Tom "DemonBlueDays" Williams
1976 SE6 #141 "Mighty"
2009 Fox "King"
Former Owner Of
Terry H
Been thanked: 50 times
Post by Terry H » Mon Aug 19, 2019 12:33 pm
I have an early BL key and complete ignition that I used to plug into your car to start it when the ignition played up some years ago. Turned out to be the ignition switch that time. I may have a switch in the garage but not known if it's a good one or not. I seem to remember Corky supplying me an ignition lock and keys some time ago. Not sure if I still have that as a spare or not.
Regards Terry H
demonbluedays
Post by demonbluedays » Mon Aug 19, 2019 12:57 pm
Managed to free the system up a bit and contact block is confirmed to be the culprit as once split the barrel spun around nicely, have managed to free the mechanism up a fair amount but she will need replacing in the not too distant future
2009 Fox "King"
Former Owner Of
Has thanked: 48 times
Been thanked: 177 times
Post by gtcse8 » Mon Aug 19, 2019 1:55 pm
demonbluedays wrote:
Mon Aug 19, 2019 12:06 pm
at worst I may need a new barrel
Tom I keep New ones in, and I have a few ignition switches left Too??.
demonbluedays
Post by demonbluedays » Mon Aug 19, 2019 2:21 pm
Thinking out loud....just pulling it apart and running a brush on the inside has appeared to have taken most but not all of the stiffness away, would putting some sort of lubricant onto the said area help with this issue?
2009 Fox "King"
Former Owner Of
