Ben's SS1 - Ti Sprint Car
- reliant-reviver
- RSSOC Member
- Has thanked: 99 times
- Been thanked: 149 times
Ben's SS1 - Ti Clutch
Had this when I "cleaned" the air flow mass sensor.
Might be worth checking it's not gotten wet or such, I think a fault will send it into a safety mode where it softly bumps up to 2k rpm
- Corky
- RSSOC Member
- Has thanked: 271 times
- Been thanked: 220 times
CAS is in the dizzy.
I have a spare working dizzy here that I can lend you for Ty Croes if it turns out to be that.
- RSSOC Member
- Has thanked: 87 times
- Been thanked: 45 times
- reliant-reviver
- RSSOC Member
Ah beaten to it as I typed it. Oh well. Nice to know I was in the right area.
- RSSOC Member
Small update I have always found and been told my car was a bit willowy through the corners so after the last event 3 sisters I have fitted 300lb springs supplied via Mr RR (Thanks) and 240lb 10.5” long at the rear.
After a couple of short trips front is riding 150mm from floor to sills and rear about 170mm rear spring seat wound about 20mm up. Think this might settle a little lower after a few more trips?
Oh and fitted some new to me wheels I have had powder coated
- reliant-reviver
- RSSOC Member
Tyre size?
- scimjim
- RSSOC Member
- Has thanked: 146 times
- Been thanked: 1023 times
I doubt new springs will settle much in the short term - could probably go a bit lower all round and a bit extra at the back?
- reliant-reviver
- RSSOC Member
Bring down the rear to level it up. 150mm at the sills is absolutely fine. Better to be at that height than too low.
- swoakes
- RSSOC Member
- Has thanked: 45 times
- Been thanked: 105 times
Tart
- RSSOC Member
- RSSOC Member
Whoops
So not stripped it down yet....
Will be looking for the following in Brecon Gold
Drivers wing
Nose come
Headlight panel
Also need
Headlight
Drivers side headlight lift mechanism
Front armature
Radiator shroud
Will post wanted add
Drivers wing
Nose come
Headlight panel
Also need
Headlight
Front armature
Radiator shroud
