Ben's SS1 - Ti Clutch
Has thanked: 174 times
Been thanked: 175 times
Post by Corky » Thu Nov 15, 2018 4:00 pm
reliant-reviver wrote:
Thu Nov 15, 2018 3:40 pm
The b*stard but need not be a problem. You just need the tools to suit.
Reminds me of a Billy Connolly quote ”there’s no such thing as bad weather, just the wrong clothes”.
Has thanked: 308 times
Been thanked: 244 times
Post by CNHSS1 » Thu Nov 15, 2018 4:28 pm
Really RR you do spout utter bollox sometimes! With all the bent spanners at my disposal, plus some I modifed with oxy flame, 'that' nut is always a pain, especially if the manifolds not been off since leaving the factory. Copious soaking with proper penetrating liquid (not WD40 or AJL will start to twitch bless him!) And ideally a good cleaning up with a mini wire brush, all by Braille as one can't get ones bonce down there to see, and even once all the prep has been done, the nut is very often corroded having been heated to 700degrees every day the car was run, so will be soft or mishappen. A mirror or even better USB endoscope connected to your phone will at least help get correct purchase on the nut with whichever spanner you choose so as not to risk rounding off. Even then, the stud may wind out of the head, jamming the spanner against the turbo/manifold making it an even less enjoyable task.
The process shouldn't be made light of, as if someone hasn't attempted before they need to be prepared before tackling it, giving the task a much much higher chance of success without succumbing to a gallon of shells finest and a Zippo and torching the bloody thing
You'll be fine, just heed the warnings of those more mature than him of the funny hair, and it'll be cool, slowly slowly catchy monkey.
If you send me your postal address I'll loan you a few 'special' spanners mate
Has thanked: 122 times
Been thanked: 909 times
Post by scimjim » Thu Nov 15, 2018 4:33 pm
Just recently done the HG on snotty - and of course, the manifold nuts were a different size to the special tool I made last time I did the job :D
Even with the right tools, you can still only get a flat or two at a time, so it takes ages.
Dcrosby13
Post by Dcrosby13 » Thu Nov 15, 2018 4:34 pm
this might sound extreme but pulling the engine and gearbox made it much easier, especially if its not been apart in a long time. still a pig though.
I break stuff...... :w
Dcrosby13
Post by Dcrosby13 » Thu Nov 15, 2018 4:35 pm
Ben once the rear end of mine is back together you are welcome to come and use my crane to pull the engine if you want.
Has thanked: 82 times
Been thanked: 128 times
Post by reliant-reviver » Thu Nov 15, 2018 4:50 pm
Could have removed the bloomin nut in the time it took to write that Craig!
It is still a "b*stard nut" mind and time consuming. But straight forward enough if a little tedious.
You can even get ratchet S shape spanners. There's a tool for everything these days...
Post by scimjim » Thu Nov 15, 2018 6:15 pm
Ratchet ones don’t fit, the ratchet mechanism makes them too big.
td99
Been thanked: 22 times
Post by td99 » Thu Nov 15, 2018 6:58 pm
Or just make your own...
There's also an offset for the ring upwards in relation to spanner body in this photo/plane.
This gets it undone and then good and tight!
B-Nut Tool.JPG (60.61 KiB) Viewed 556 times
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Benc
Has thanked: 47 times
Been thanked: 26 times
Post by Benc » Thu Nov 15, 2018 8:08 pm
Chaps
Which is this fatherless nut you all fear.....
Answers by pictures :D
td99
Post by td99 » Thu Nov 15, 2018 8:14 pm
No picture possible until you've removed the manifold. Then, what's the point!
It's at the front underneath of the manifold.
Best to remove distributor to gain clearance whatever spanner.
Has thanked: 85 times
Been thanked: 100 times
Post by b.c.flat hat » Thu Nov 15, 2018 8:18 pm
Never trusted wedge pedallers, there's voodoo involved😜
td99
Post by td99 » Thu Nov 15, 2018 8:26 pm
That's why they go faster :P :P :P
Benc
Post by Benc » Thu Nov 15, 2018 8:29 pm
Ah BC I have one of each :w
Dcrosby13
Post by Dcrosby13 » Thu Nov 15, 2018 8:30 pm
No one has ever actually managed to take a picture of the fabled creature Ben
Post by CNHSS1 » Thu Nov 15, 2018 8:50 pm
When rebuilding after removal, I use either a normal nut, and spin on with fingers and then just tighten last few flats, or in have used genuine Nissan nuts which are a spanner size smaller than the norm for that thread diameter 12mm vs 13mm as norm iirc. Only issue witj genuine Nissan ones is that they are slightly crimped at one end so they don't loosen by themselves (fat bloody chance :lol: ) so you need to wind them in and off a spare stud in the vice or run a tap through, just to rid the crimped self grip bit.
I use crimped tri-loc aftermarket nuts on the other 5 studs where access is normal
