1982 GTC project gumtree
ard126k
Post by ard126k » Sat Apr 29, 2017 9:51 pm
I'm still waiting to hear from the PO if he has the bits I'm missing but I'll not forget.
This week's hiccup is engine timing, I don't have any marks on the block to relate the pulley notch to! My Granada handbook shows a row of about 5 teeth on the block but I've not got them. There is a bolt head in roughly the right place - are the teeth bolted onto the block?
Alex.
1971 SE5 1977 SE6 1982 GTC
Has thanked: 41 times
Been thanked: 210 times
Re: 1982 GTC project gumtree
Post by AJL Electronics » Sat Apr 29, 2017 9:58 pm
Yes it is a little add on piece with the teeth. It bolts to the timing cover. You could do it by marking TDC then setting the advance you want on a timing gun.
ard126k
Post by ard126k » Sun Apr 30, 2017 5:46 pm
I'll have another look through the boxes that came with the car, maybe I didn't even realise what I was looking at. There's one on eBay just now so I'll recognise it this time
ard126k
Post by ard126k » Mon May 01, 2017 9:26 am
I also need to refit the crank pulley and instead of the usual keyway I've got a pulley with 4 boltholes and a hole for a spigot in the crank
No mention of such a thing in the Haynes book, I assume it's a later/better/cheaper way of fixing the pulley?
Alex.
Been thanked: 840 times
Post by scimjim » Mon May 01, 2017 9:29 am
Looks more like the additional pulley for PAS/AC to me? Far too weedy to be the crank pulley - and no balance weights/cutouts.
ard126k
Post by ard126k » Mon May 01, 2017 9:43 am
This is the end of the crank. You'll have to trust me about the keyway, but you can see the spigot around 4 o'clock
and this is the only other pulley I have which would go in front of the first one and do the PAS -
Post by scimjim » Mon May 01, 2017 10:04 am
That's not the end of the crank, it's the damper - which is keywayed into the crank.
Post by scimjim » Mon May 01, 2017 10:05 am
Post by AJL Electronics » Mon May 01, 2017 11:10 am
ard126k
Post by ard126k » Mon May 01, 2017 5:28 pm
Thanks both, that's cleared up the confusion and let me check the valve clearances this afternoon.
I notice there are two designs of the timing 'teeth' - any significant difference between them?
Alex.
Post by AJL Electronics » Mon May 01, 2017 5:46 pm
The mucky ones are 2.8, the other is 2.9i
ard126k
Post by ard126k » Wed May 03, 2017 1:59 pm
My version -
Just off to the 'Wanted' section to see if anyone has a spare set of teeth, and the clamp plate for the distributor, and a PAS pipe...
Alex.
ard126k
Post by ard126k » Fri May 05, 2017 2:45 pm
Today's problem is plumbing - can anyone tell me what route the fuel pipe should take between pump and carb? I've got these two pipes in the 'kit of parts' which look like they are to do with fuel but I can't make them fit even roughly around the engine area -
for scale, that spirit level is 2ft long...
There are two clips on the LH engine mount that look like they may be for a fuel pipe.
I have two Weber carbs (yes, I know I only need one) - am I right that a Solex carb would have its throttle cable coming from the left not the right?
TIA
Alex.
Post by greeny » Fri May 05, 2017 3:53 pm
I am not 100% about this but they look more like power steering pipes to me?
Post by scimjim » Fri May 05, 2017 4:24 pm
I think they're the fuel pipes - they bolt to the timing cover IIRC (the return may bolt to the inlet manifold? Not sure on exact location on the Cologne.
