1982 GTC project gumtree
petermisy
Post by petermisy » Tue Oct 31, 2017 10:05 pm
I think you are referring to the plate under the catch going into the windscreen head slot at the front?
Up, so when the go into the slot the headrail is pulled down slightly.
Peter
GTC Prototype XJW 247T
GTC No. 381 A381 GTC (was A24 EPB)
MGB GT 1971 EPE 838J (project)
2016 Ford Galaxy Titanium X 180bhp
Ford Transit Connect van
2016 Bailey Pegasus Verona Caravan
ard126k
Post by ard126k » Wed Nov 01, 2017 11:16 am
Sorry that wasn't clear Dennis. Thanks for the tip about the door frames - I'll try to remember that when the time comes. I think I would have been inclined to fit the doors with the hardtop in place, on the basis that it's a fixed size and the soft top isn't !!
Got it, Peter thanks.
1971 SE5 1977 SE6 1982 GTC
ard126k
Post by ard126k » Tue Nov 21, 2017 12:02 am
The rear seats are now installed, and I notice that the backs sit up straighter (less reclined) than on the SE6a. Is this a design feature to allow the hood to lie behind them I wonder, or have I got something else wrong?
Been thanked: 73 times
Post by DARK STAR » Tue Nov 21, 2017 6:15 am
I think mine are more upright than a GTE too, but I have no direct comparison.
You can help me this time, I want to replace a button on the rear seat, how do you get it out ?!
ard126k
Post by ard126k » Tue Nov 21, 2017 9:53 am
Is it on the base, or the back? Base is easy, if you get it out of the car you'll find the ends of the string which holds the button in place, just untie and remove. You may need a new length of string as they're only just long enough (trimmed after installation) and so hard to re-tie.
I haven't investigated the GTC backs, but on the front seats of a 6a the strings go over a bar of the seat frame and then tie off to another bar towards the bottom of the back. I would guess that if you remove the panel behind your seat back you should reveal the strings.
I had to re-cover some of my buttons and I managed it in situ. I cut off the worn bits of the old covers with nail scissors then pinched a bit of velour from a hidden corner under the seat base and cut it to fit the button with little fingers to tuck behind. Think 8-pointed star or sherriff's badge! Then a dab of contact glue on the button face and tuck the fingers under. They look ok from the front seats, time will tell how they hold up to use. These are velour cloth seats, but I imagine leather would work similarly.
Best of luck!!
Dennis Nicholas
Has thanked: 17 times
Been thanked: 22 times
Post by Dennis Nicholas » Tue Nov 21, 2017 10:39 am
I have just done that on my GTC.
Undo the nuts and pivots that hold the back to the base and when you remove the back you will see how the upholstery is held on to the frame by push on clips along the bottom. They are spring steel U shaped with 2 little sharp spikes that point in-between the faces of the clip and dig into the frame metal to stay put (and form a small paint piercing rust starter area :( ) The clips can be prized off so that the upholstery will be free of the frame.
The upholstery is just a big bag pulled down over the seat back frame and padding. You may have to take off the seat reclining handle if you have difficulty getting access to the higher up buttons but I managed without having to do that. Each button has a loop of metal on the back. a thin strong string is doubled up and the fold pushed through the loop then opened up and passed over the loop and pulled tight on itself so it is held in place around the outside of the loop. The free ends of the string pass through the padding and go over metal bars from front to back and down to the base of the seat back where they are tied off on another bar under slight tension (to pull the button/upholstery inwards). When you take the back off and take the clips off all will be revealed. You may find that only one of the legs of the doubled up string is snapped so you can tie another bit onto it. When you pull the button out a LITTLE take the string with it so you can use the old string to pull the new through if needs be. Otherwise you will need a large needle to push through the padding and pull new string through leaving loop on surface to thread through and over button loop......then pull string tight and tie off on bottom bar. There are two bars that the string go over...you will see one near top and second further down.
The buttons have a front cup and a back with metal loop. The upholstery is put over the front cup and the back is pressed into the cup to hold material captive and gets slightly crimped in place......best of luck!!!!! My mouse eaten one had to be recovered with a small piece cut off the surplus where it is clipped on at the bottom (usually plenty of spare material just pushed in after clipping to frame. You can prise the 2 halves of the button apart VERY CAREFULLY but crimping back almost impossible without correct tool. I glued material onto front cup and stuffed into back again held with glue clamped in place with layer of plastic so clamp would not get stuck to button. Then put back part on having filled hollow with glue (araldite) and slightly crimped if possible and again clamped the two together and left to dry. It is worth painting button.....they rust when they get wet (those times you get caught out in a deluge with hood down on motorway!
This was a good opportunity to put a thin nylon washer between all metal surfaces that rub together when pivoting the seat. Old plastic food containers with thin lids can be used to make the washers.....another paint-scraped-off- rust potential area fixed.
Sorry about long winded description but it will at least give an idea and it is not too difficult. Believe you can probably buy buttons ready done, but colour match??
Dennis
Dennis Nicholas(RSSOC)
ard126k
Post by ard126k » Tue Nov 21, 2017 11:24 am
There are buttons you can cover yourself. Have a search. I can remember my mum using them in the 50s......
Post by DARK STAR » Tue Nov 21, 2017 11:38 am
Thanks for all your advice, and sorry to hijack the thread.
I should make myself clear 8) I have the button and know how to replace it (I have done others)
But I don't know how to get the seat base out of the car ...
Been thanked: 876 times
Post by scimjim » Tue Nov 21, 2017 11:42 am
There are a couple of hidden screws on the 6b/GTC under the inertia reel covers (which are part of the seat base on the late cars).
ard126k
Post by ard126k » Tue Nov 21, 2017 11:43 am
There are 2 brackets at the front (under the carpet) to unscrew.
Post by DARK STAR » Tue Nov 21, 2017 11:57 am
Thanks, I'll have a grovel in the rear footwell :D
Has thanked: 128 times
Been thanked: 483 times
Post by Roger Pennington » Tue Nov 21, 2017 12:08 pm
Later 6as had the fixing screws too :) Once the screws are undone, you may find the seat base still won't come out, especially if there has been damp around, as the fibreglass underside tends to get stuck to the insulating foam on the floor. So it may need a fairly firm pull to shift it.
ard126k
Post by ard126k » Tue Dec 26, 2017 3:20 pm
The car is now at the painter's shop, he sent a couple of pics of the progress -
original paint gone -
etching primer on -
in grey primer -
Post by DARK STAR » Tue Dec 26, 2017 5:12 pm
Oh yes!
ard126k
Post by ard126k » Wed Jan 03, 2018 8:14 pm
Couple more pics from before the hols.
