RFE666K
luke
RFE666K
Post by luke » Sun Jan 15, 2017 10:11 am
Hello all, finally started work on my 72SE5a. She has sat for a while, got the engine running, quite a few of the core plugs are leaking, so the engine is coming out, for a top end rebuild, a steel timing gear is going in too.
The over drive works well, tested it with the car set up on axle stands.
It has had body reinforcement sections replaced in the A pillar.
Chassis looks ok, except for the near side front out rigger which isn't actually attached to the chassis any more!
I have a folder an inch thick with service history going back to the 70's.
I'll try and get more photos posted!
luke
Re: RFE666K
Post by luke » Sun Jan 15, 2017 10:18 am
picture of the side. got the door back on now
luke
Re: RFE666K
Post by luke » Sun Jan 15, 2017 10:25 am
my mrs isn't keen on the devil number plate!
Re: RFE666K
Post by greeny » Sun Jan 15, 2017 11:46 am
Great colour!! Good luck with the build
