Grawpy
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 7:50 pm
New foam for the heater blower
And this is how I left it
Been thanked: 26 times
Re: Grawpy
Post by nickkeyser » Tue Jan 10, 2017 8:58 pm
That baffle arrangement suggests both are later sumps, I've seen some with much less baffling in them. Could the aditional hole align with either an oil drain above, or the turbo oil drain?
Re: Grawpy
Post by scimjim » Tue Jan 10, 2017 9:17 pm
nickkeyser wrote:That baffle arrangement suggests both are later sumps, I've seen some with much less baffling in them. Could the aditional hole align with either an oil drain above, or the turbo oil drain?
One from a "Reliant" 1600 and one from the CVH-PTE Nick. I have half a dozen others under the bench but I'm not taking them off the engines to check :-)
Re: Grawpy
Post by nickkeyser » Tue Jan 10, 2017 10:39 pm
Yup - my thinking was that from what I've seen they go more with year rather than fitment/spec. The escort S2 /fiesta RS Turbo uses the same sump baffle, and that hole looks to be directly inline with the oil drain which is via a spigot in the block on the flat near the starter motor (the flat is bigger on later blocks). So the hole may be related to the year, rather than FWD/RWD.
Has thanked: 75 times
Been thanked: 118 times
Re: Grawpy
Post by reliant-reviver » Wed Jan 11, 2017 1:19 pm
I've come across original Ford sumps with:
Flat flange (3pc gasket) with bowl baffle (81 part number)
Flat flange with full length windage tray (from an 85 SS1)
Bumped flange (1pc rubber gasket ) with windage tray. These are the now common sumps and probably fitted from everything post 1985(?) in line with the oil pump revision
Re: Grawpy
Post by scimjim » Sun Jan 29, 2017 10:26 pm
Back from skiing so I managed to get a bit done on this. Front hubs and discs refitted, calipers cleaned up, freed off and the lips taken off the pads and one lower balljoint replaced. One rear slave cylinder is leaking so full refurb to be carried out on both sides. Refitted the wiper motor with replacement wheelbox (great job :-)) and secured the ECU mount
Been thanked: 539 times
Re: Grawpy
Post by philhoward » Sun Jan 29, 2017 10:31 pm
Found an ECU then?
Re: Grawpy
Post by scimjim » Sun Jan 29, 2017 10:31 pm
wheels on temporarily so that I can move it if I get time to MOT snotty before Geoff's funeral
Re: Grawpy
Post by scimjim » Sun Jan 29, 2017 10:32 pm
philhoward wrote:Found an ECU then?
No, I have a couple on the shelf - 2.9i IIRC.
Re: Grawpy
Post by philhoward » Sun Jan 29, 2017 10:32 pm
Ah - mockup then.
Re: Grawpy
Post by scimjim » Sun Jan 29, 2017 10:40 pm
Yep, still looking for a reasonably priced one - can't find anything about the maps and whether a 1.6 would work on the 1.4.
Re: Grawpy
Post by philhoward » Sun Jan 29, 2017 10:55 pm
Asssiming the pinout of the ECU is the same and you use a 1.6 AFM plus injectors then it should run although it might complain a little as it will only see 87.5% of the airflow it expects. I think EEC-IV Is a bit self-learning though (or is that only EEC-V?).
Re: Grawpy
Post by scimjim » Sun Jan 29, 2017 11:10 pm
I don't think EEC-IV is self learning. AFM appears to be the same part number (also used on the Zetecs) but TB is much smaller on the 1.4.
Re: Grawpy
Post by scimjim » Sun Mar 05, 2017 9:06 am
Refurbished the leaky rear brakes yesterday and replaced a couple of suspect springs
Re: Grawpy
Post by scimjim » Sun Mar 05, 2017 5:53 pm
Modified the throttle bracket from a round hole, to a square one, then modified the standard throttle cable to give me the full range of movement. Not sure how long it will last with a plastic nipple but I've ordered a solder nipple in case I need a mk2 version :-)
After taking this pic I modified the bracket to give the cable a straighter run at the wheel.
