Grawpy
Has thanked: 157 times
Been thanked: 1080 times
Grawpy
Post by scimjim » Sat Jan 07, 2017 7:12 pm
Grawpy is a galv 1400 SS1 belonging to Sam. After blowing the engine up on the way back from France 4 or 5 years ago, we fitted an unknown 1600 and 5 speed box. After years of daily commuting it's now using more oil than petrol, the paint is pretty faded, the interior has seen better days, the diff is leaking and the Carlton discs are causing brake judder and were borderline on the MOT.
Options for the engine were:
Rebuild the 1600
Fit another 1600
Fit the 1.8 MX5 engine and box that's waiting for a new home
Fit the 1400 injection CVH that's been waiting for a home for many years.
Eventually we decided on the 1.4i because the MX5 needed a bit too much work that we haven't trialled yet (dash clocks, speedo cable, prop, gearbox mount and electrics. We've only really looked at engine mounts and exhaust so far). The iCVH needs a trigger wheel and the fuel system upgrading to injection (Sabre Ti tank fitted, pipes replaced and electric pump fitted).
DJ changed the diff before Christmas (we had a 3.62 ready for the MX5 option) - a standard 3.92 went in.
I changed the discs last weekend - the old ones were really worn!
The old engine came out quite easily
and after throwing some paint at it and replacing some seals,
the new one went in today
erikscimitardemon
Been thanked: 21 times
Re: Grawpy
Post by erikscimitardemon » Sun Jan 08, 2017 9:04 am
You've been busy!
Erik Hofman
http://www.scimitar.demon.nl
Been thanked: 395 times
Re: Grawpy
Post by peter freeman » Sun Jan 08, 2017 9:18 am
Personally I would have gone for the Nissan engine as I'm not a fan of the CVH - no idea what difference the injection makes to it though so will watch with interest as the job progresses.
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 9:57 am
Unfortunately I sold the turbo from my spare Ti to a forum member in need.
I have a Ti engine, ECU, loom, exhaust manifold, gearbox and instruments but along with a turbo, would need a prop & AFM - if the unknown engine needed any work, the conversion could get expensive.
Re: Grawpy
Post by peter freeman » Sun Jan 08, 2017 10:01 am
Ah well time will tell - best of luck with it anyway.
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 10:02 am
I think this will also be interesting to see if it's true that the last of the CVH engines were the best of the bunch. Apart from being rough around the edges (NVH) and underpowered from the factory, if you look after them they are fairly bulletproof to begin with and very simple to work on. I recall driving a friends new fiesta Si with this engine and was quite impressed at the time (although I was driving a 1300 spitfire then :-))
Has thanked: 86 times
Been thanked: 725 times
Re: Grawpy
Post by philhoward » Sun Jan 08, 2017 10:56 am
Why go for a trigger wheel on the pulley end? Use the EFi flywheel, and a Mondeo Clutch (just like you'd do when fitting a Zetec) with the standard sensor location? In fact, I thought that only an EFi flywheel fits an EFi crank as one of the holes is slightly off-pitch?
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 3:55 pm
All CVH flywheels are interchangeable AFAIK - certainly the one that I fitted has the offset holes. Unfortunately the engine came without a flywheel (or is long lost :-)) and it's fitted now!
Been thanked: 49 times
Re: Grawpy
Post by nickkeyser » Sun Jan 08, 2017 4:06 pm
Cool project. Has anyone else run one of these EFi manifolds / CVH injection on an SS1 before?
SSSC Champion 2019
SS1 CVH 1600Ti
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 4:36 pm
I think there may be one undocumented 1600EFi running around? I have a 1600EFi head and inlet too :-)
Has thanked: 210 times
Been thanked: 111 times
Re: Grawpy
Post by efi_sprintgte » Sun Jan 08, 2017 5:31 pm
I recall my mates RS turbo that was MFI and we megasquirt EFI'd.. we built a new engine up based on a injection block and crank and we had to use a different flywheel I'm sure.
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 7:37 pm
Took the opportunity to see if there's any difference between FWD and RWD sumps
RWD:
FWD:
The additional hole (bottom left of pic) could just be a later addition but it's the only difference I can see.
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 7:40 pm
A little CAD to cover the crank position sensor hole
And 2 minutes with a bit of GRP:
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 7:42 pm
The old v new Carlton discs
And this may explain the vibration
Re: Grawpy
Post by scimjim » Sun Jan 08, 2017 7:48 pm
A little wiring. Replace the ring end on the starter motor to alternator wire
Replace the metal tape on the wires that run near the exhaust
and add loom tape
Then moved onto the hard stuff :-)
