SS1 - Istrian Bue 1600
MarkHawkins
Re: SS1 - Istrian Bue 1600
Post by MarkHawkins » Tue Aug 30, 2016 5:03 pm
MoT booked for Saturday. Have been quoted £60 a wheel to make them round again. So the plan is to see what the MoT throws up before spending out on wheels / tyres.
Red / Blue anti freeze question because the Reliant Manual that came with the car seemed to suggest Ford long life red antifreeze.
Custodian of :
1968 '4b Coupe HBL 725G
ex 1974 '5a auto - VLN 826M
MadMax
Post by MadMax » Tue Aug 30, 2016 5:44 pm
Interesting, I read that antifreeze colours don't always correlate to their properties.
Max Benton
Reading, Berks
'Zeus' - Yellow SE5a
Has thanked: 31 times
Been thanked: 43 times
Post by Alan SS1 » Tue Aug 30, 2016 6:42 pm
AJL Electronics wrote:It's not so much the silicone as the solder joints and brass components of the cooling system. Euroboxes are made with plastics, so OAT will work without causing problems.
good job i use old blu-col then as the pipe running from back of pump to back of block (under exhaust) is a home made using 1/2" or 15mm&22mm from plumb-center :D
NB the heater certainly has brass stubs on mine, no idea what's inside as so long since looked at it . . . . .
MarkHawkins
Post by MarkHawkins » Sat Sep 03, 2016 11:10 am
Went for MoT today - one bottom ball joint bad and handbrake not working well on one wheel plus an overly dim number plate bulb. I believe the bottom ball joints are from Chevettes - the local motor factors say they should have some in on Monday at £10 each.
Custodian of :
MarkHawkins
Post by MarkHawkins » Tue Sep 13, 2016 2:06 pm
MoT now passed. Learner insurance purchased. Now for some road tax and L-plates.
Custodian of :
Has thanked: 144 times
Been thanked: 525 times
Post by Roger Pennington » Wed Sep 14, 2016 1:28 am
Well done on the MOT! :D
MarkHawkins
Post by MarkHawkins » Wed Sep 14, 2016 9:58 am
Thanks. Now taxed and ready for William to drive to his work experience placement rebuilding Jensens. The 1600 / 5 speed is a big improvement over the 1300 / 4 speed.
Custodian of :
MarkHawkins
Post by MarkHawkins » Wed Sep 14, 2016 10:01 pm
L plates fitted and a couple of trial runs out - all OK but have noticed the lights aren't as good as those on the 'big' Scimitars.
Custodian of :
Post by Alan SS1 » Wed Sep 14, 2016 10:21 pm
Probably as lights are a wee bit lower than on a GTE? so the light beam can't reach out as far before hits the road... maybe halogens in GTE?
or as you are going faster in the SS1 vs GTE they appear poorer due to 'overtaking' the illuminated zone :-)
td99
Has thanked: 17 times
Been thanked: 27 times
Post by td99 » Thu Sep 15, 2016 9:31 am
SS1 dipped beams as original suffer from a tortuous route through a plethora of switches and relays, resulting in reduced voltage at lights, thus lower light output. That coupled to p*ss poor beam-forming by the reflectors gives miserable lighting.
If not already done, use the existing dipped beam wiring to activate relay providing 12 V direct from battery (but of course fused).
It's possible to modify the wiring to existing fuses to do this.
Consider better bulbs.
Bi-Xenon conversion is also possible.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
MarkHawkins
Post by MarkHawkins » Thu Sep 15, 2016 9:58 am
I think the first thing to do will be to ensure both reflectors are good (one slightly dull) then change the bulbs. Yes, halogens in the GTEs and the 5a has been set up as 4 dip / 4 main so nice and bright.
Custodian of :
MarkHawkins
Post by MarkHawkins » Mon Oct 24, 2016 8:40 pm
I fitted headlights Jim supplied the other week and they are much better. Both doors managed to lock themselves shut today but a few minutes with a metal hook we'd fashioned earlier in the year to help fit the GTC bonnet release cable had it open. Bucket seats are now stretched to fit better and some shiny round 14" 'bottle tops' have been obtained from Phillip A.
Custodian of :
