Manny's SS1 1600
manny
Has thanked: 33 times
Manny's SS1 1600
Post by manny » Sun May 20, 2018 10:06 pm
scimjim wrote:
Sun May 20, 2018 10:00 pm
I probably have spares - can look tomorrow if you want?
just the body or whole dizzy? pm me either way please
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Thu May 24, 2018 9:28 pm
Good (lovely) day all,
today i started planning on how\where to place the ignition amplifier- as i experienced the same symptoms last sunday - when it was a very warm day and my car had been idling on the driveway - i got about 100m before the car just died... this is after the new coil and amplifier :( ..unperturbed i used the car on Tuesday - but this time drove it within 30 secs of starting with a little choke - and it was absolutely fine.. this may not be the best approach ..but so far
the surface components were easy to scrape off..
going to mount it on a CPU heatsink and use a CISCO SS bracket on the nearside inner arch..
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Fri May 25, 2018 10:06 am
Boo to me\car...
this morning - it was reluctant to start - when it did - seemed like three cylinders....stuttering during the first 10 mins and then conked out entirely - so i had it run home in the rain for 2 miles to get the euro box :( :(
boo
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Been thanked: 840 times
Manny's SS1 1600
Post by scimjim » Fri May 25, 2018 12:23 pm
I’d just put a new amp on the dizzy I just posted to you with plenty of heatsink paste.
manny
Manny's SS1 1600
Post by manny » Fri May 25, 2018 12:41 pm
Thanks Jim , yep will do -although the current amp is less than 4 months old!
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sun Jun 10, 2018 8:12 am
Good day all,
yesterday i moved the the ignition amplifier to the bulkhead ( mock up for testing) and ran a direct lead to the -VE post - all fired up nicely - left it idling for 25 mins - heatsink was slightly warm to the touch - so hopefully all should be well.
I also replaced the O ring on the distributor supplied by Mr JIm King...my old one was a three lug but one lug had been snapped off..
I am still puzzled by the fact my engine runs best idle vacuum when the distributor is at the end of its rotational limit- so i hooked up a vacuum gauge at the T take of for the vac unit- and observed the needle was rapidly fluctuating between the 17-14 inches of Mg- but steadied when i adjusted the distributor at the end of its travel - searching the net suggests its worn valve guides....?
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Sun Jun 10, 2018 5:01 pm
Went for a 30 mine drive - cut out twice - restarted with full choke - and then about 50m from home broke down again - the car would appear to fire up and then just die... :( :(
I popped the bonnet - the ignition amplifier was warm to to touch - the coil was considerably hotter- but not enough to burn...so back to square one ...will try to restart after a few hours...buggga!!
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
manny
Manny's SS1 1600
Post by manny » Mon Jun 11, 2018 6:53 am
Good day all
no luck in starting and keeping it running - i tried last night a few hours after breaking down- swapped the coil - same result- tried the previous amplifier as a last resort...in the end we pushed it on to the drive
So now i have ordered three amplifiers and a spare coil - as i need to use the car on Saturday for 120 mile round trip...
Bugga...
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
Manny's SS1 1600
Post by scimjim » Mon Jun 11, 2018 7:51 am
Are you checking for a spark with each replaced part?
Has thanked: 72 times
Been thanked: 117 times
Manny's SS1 1600
Post by reliant-reviver » Mon Jun 11, 2018 8:16 am
Are you sure it's not fuel related? Worth fitting a clear inline filter just to keep an eye on it and make sure you haven't got any water circulating in the system.
Perhaps check also the resistance of the ignition leads and the rotor arm - I have known these to fail, although admittedly in both instances when I had one "go" it was a loss of power and no restart sort of situation.
Been thanked: 534 times
Manny's SS1 1600
Post by philhoward » Mon Jun 11, 2018 9:01 am
It does seem like water in the fuel to me..
manny
Manny's SS1 1600
Post by manny » Mon Jun 11, 2018 11:42 am
Water in the tank was definitely one of my thoughts, as i had left the car idling on the drive ( inclined) when i first 'fixed' it - the nose was higher - so it may well have been petrol being drawn ( half a tank ) - but as the car died on a slight incline finally - i was hoping that water was not a possibility.
I do have a one of those large suction pumps\syringe- so..
If i jack the jack at the rear so it is higher than the nose..
Attach the syringe to the carb inlet pipe ( fed from a fuel filter)...
That should enough to diagnose the water theory??
Ta
Manny
Manny's SS1 1600
Post by scimjim » Mon Jun 11, 2018 11:59 am
Disconnect fuel pump to carb pipe and pump some fuel into a glass jar using the starter motor - water will separate from fuel.
The pipe in the fuel tank reaches to the bottom of the tank, so inclines shouldn’t affect it much if it’s half full.
Manny's SS1 1600
Post by philhoward » Mon Jun 11, 2018 12:00 pm
Realistically the only way is have a peek inside the tank - through the sender - but your way sounds about right. I'd have it level though, otherwise the water will pool into a corner.
I'm not sure if it is the fuel I was using or the fact it was an injection engine (so had a high pressure re-circulation system) but water would end up as a milky layer at the bottom of the tank. Pulling some out of the tank (in my case, running the pump whilst having the feed line pointing into a receptacle) would see it separate in a glass jar.
manny
Manny's SS1 1600
Post by manny » Mon Jun 11, 2018 1:50 pm
Good day all
will check the fuel bowl as well...thank you sirs ... another member has highlighted the idle shut off solenoid - which i was half considering...i assume applying 12v (engine off) to it will prove it either works or not..?
Ta
Manny
GTE Progress#
Ti Progress#
1600 Progress#
GTC Progress#
