Manny's SS1 1800 Ti
Has thanked: 572 times
Been thanked: 499 times
Re: Manny's SS1 1800 Ti
Post by CNHSS1 » Sun May 01, 2016 12:36 pm
GOOD WORK :-)
manny
Been thanked: 26 times
Post by manny » Sat May 14, 2016 10:27 am
good day all,
progress so far using a combination of
Image Image
and tremendous lack of skill
I have managed to get the big crack down to metal ( was quite deep and I was worried about the mounting area) - just flattening left - but I think i may struggle to get the manifold looking like ' the correct way' as posted by Mr' CNHSS1'
I wont post the pics of how my drill is braced :shock:
I will crack on to try and get more metal removed\smoothed but hopefully its going to end well.
have a lovely day
Ta
Manny
manny
Post by manny » Sun May 15, 2016 11:02 am
good day all,
as i am nearing the point of reinstalling the turbo bits in the car -
I have emailed a company requesting a set of new banjo bolts and washers.
Does the oil drain pipe-sump also need a washer?
the manifold will be shotblasted and turbo surface flattened
Ta
Manny
Post by CNHSS1 » Sun May 15, 2016 11:15 am
The oil drain stub from turbo core usually has a two bolt flange fixing with a paper gasket
manny
Post by manny » Sun May 15, 2016 11:35 am
CNHSS1 wrote:The oil drain stub from turbo core usually has a two bolt flange fixing with a paper gasket
hmm..maybe i have identified the part wrong...
can't see a flange fitment...??
Post by CNHSS1 » Sun May 15, 2016 11:42 am
Ah different core than normal.
I suspect thats a pipe thread so slightly tapered, its under naff all pressure so unlikely to be an issue
manny
Post by manny » Sun May 15, 2016 12:13 pm
cool...thanks for that sir...now you got me intrigued.....were the cores for the T2 different depending on the end installation? - or is mine not the standard unit as fitted by the factory.
this is how the manifold now looks...have i done enough?
Post by CNHSS1 » Sun May 15, 2016 1:20 pm
Manifolds perfect! You should have no more issues there 8)
To be honest that may be the oem reliant fitting thinking about it, had so many T2/25/28 frame turbos i cant remember. Wont make any difference which it is so long as it drains from core :-)
manny
Post by manny » Sun May 15, 2016 2:45 pm
CNHSS1 wrote:Manifolds perfect! You should have no more issues there 8)
sir..thank you for your calming words..probably wont stop me pestering you ...but for now all is well.. :D
manny
Post by manny » Tue May 17, 2016 4:49 pm
good day all,
dropped of the manifold for blasting today, chap asked if wanted them powder coated...as i was just considering slapping on VHT paint...any preference?? does it matter?
Ta
Manny
Post by CNHSS1 » Tue May 17, 2016 4:54 pm
If exhaust manifold the powder coating will melt off in minutes!
Ive used VHT paint and it stays on for a goodly while tbh, much better than i thought. I have some video somewhere of Batmobile on the rolling road, full boost, flat out and the exh manifold is a bright orange colour!!!! and still tge Halfords VHT black paint stayed on 8)
manny
Post by manny » Tue May 17, 2016 7:20 pm
cool will do the same
cheers
manny
Post by manny » Wed May 18, 2016 1:39 pm
good day all,
well ...it is shiny now but...
as its cast...is it just a door stop now :( ...or can it be salvaged by low power welding? I did ask the shot blasting chap....'fornicated' was his response :( :(
boo hoo
Manny
Post by CNHSS1 » Wed May 18, 2016 1:47 pm
I had one go in same place and an elbow. My tame superweldingman welded the manifold but not without some hassle, special rods andc all that, but he reckoned the elbow was even lower quality material, his exact words were 'floor sweepings', so you may well recover it, but id take it to a specialist. Alternatively, could you drill out and create a threaded bung?
manny
Post by manny » Wed May 18, 2016 1:51 pm
CNHSS1 wrote:....but id take it to a specialist. Alternatively, could you drill out and create a threaded bung?
thanks CNHSS1
specialist ...welder?..custom exhaust manufacturer?...engineering machinist ..?
