stevecrosby63
Corky's Scimitars & S2K
Post by stevecrosby63 » Wed Aug 07, 2019 6:13 pm
Good news all things considered Steve, nice to see it's not as bad as feared
Has thanked: 282 times
Been thanked: 225 times
Post by Corky » Thu Aug 08, 2019 9:44 pm
So in between going to work and everything else I’ve somehow managed to recondition, paint and strengthen a wishbone, strip a driveshaft of its tripod joint and replace it with a Sierra CV joint, paint the brake back plate and get it ready for re-assembly. I should get a couple of the hours in the morning to do this and drop it back on it’s wheels. If they all point in the same direction, I should be able to make Curbs with the car :D . If not I’ll be competing in the Honda :( :D :mrgreen:
Has thanked: 415 times
Been thanked: 350 times
Post by CNHSS1 » Thu Aug 08, 2019 10:03 pm
Good work fella 8)
Has thanked: 313 times
Been thanked: 154 times
Post by MikeyBikey » Thu Aug 08, 2019 10:04 pm
I’ve watched the video a few times. A real snatch. You Are you on 1a’s aren’t you
Post by Corky » Thu Aug 08, 2019 10:23 pm
Yes 1As, and somehow managing to beat last year’s times on Bs. But I do have an extra 23bhp.
I think I’ll go back to Bs next year though. A’s break my car :lol:
Post by MikeyBikey » Fri Aug 09, 2019 9:21 am
Well that’s just it. 1a’s have obviously let go a bit earlier but I didn’t think they’d snatch quite so hard...
Unless of course you just ran out of talent and lost control..... :W :W :W
:D
Post by CNHSS1 » Fri Aug 09, 2019 9:25 am
It was a simple snatch and spin, low speed, almost nothing, but it was the track scenery that did the damage Mike, we've all had much worse offs and done no damage
Post by MikeyBikey » Fri Aug 09, 2019 9:58 am
I was jesting, honest. I run out of talent all the time ...
In fact if i knew what i was doing it would be scary
Has thanked: 24 times
Been thanked: 104 times
Post by Coupe Racing » Fri Aug 09, 2019 11:44 am
I went straight on at Museum once ..... that was scary as there is a little more speed and nasty scenery involved.
That was just breaking way too late
Post by CNHSS1 » Fri Aug 09, 2019 12:33 pm
Most of you would drive much slower at Loton if you knew what lurked a few feet from the track!! In the winter when all the greenery has died down, you can clearly see big lumps of concrete footings from its time as WW2 munitions depot :mrgreen:
Post by CNHSS1 » Fri Aug 09, 2019 12:34 pm
That said, it's no worse than Wiscombe which doesn't hide the fact you whizz past 500yr old trees 5ft from the track 8)
Post by Corky » Fri Aug 09, 2019 8:35 pm
Update.
Replacement trailing arm assembly fitted, and rear wheels now appear to point the same direction :D
Post by Corky » Fri Aug 09, 2019 8:40 pm
The front end damage is similar.
I’ve reshaped the wishbone and fitted s new ball joint and now both front wheels point in the same direction. However, I’ve ordered a new lower wishbone as I’m worried is weakened.
Has thanked: 34 times
Been thanked: 157 times
Post by gtcse8 » Fri Aug 09, 2019 9:18 pm
Ooooops that`s bent :(
EX SST 1800Ti
Post by CNHSS1 » Fri Aug 09, 2019 9:19 pm
I have one or two just like that
