Coupe Build From Australia
Archibald Tyre
Post by Archibald Tyre » Thu Sep 07, 2017 12:14 am
WOW this is so good.
Been thanked: 75 times
Post by DARK STAR » Thu Sep 07, 2017 6:26 am
Congratulations Victor, a magnificent achievement.
MikeT
Has thanked: 21 times
Been thanked: 23 times
Post by MikeT » Thu Sep 07, 2017 8:06 am
Fanstastic! Great to hear it running :)
Has thanked: 95 times
Been thanked: 65 times
Post by efi_sprintgte » Thu Sep 07, 2017 8:19 am
Awesome build
GTC Ian
Post by GTC Ian » Thu Sep 07, 2017 8:48 am
If this was my car I wouldnt put a body on it... I would place it on a plinth and just keep looking at it. The attention to detail is breathtaking.The details of this bulid need compiling into a book not just for Scimitar owners, but all classic car enthusiasts
Members since 1984
Dave 6726
Has thanked: 53 times
Post by Dave 6726 » Thu Sep 07, 2017 9:38 am
Absolutely beautiful!
Edzed
Post by Edzed » Thu Sep 07, 2017 11:04 am
Words fail me... this is just absolutely unbelievable. Stunning workmanship! Congratulations Victor. I can't wait to see the body on the chassis and the car complete.
Jeff Craske
Current:1989 LHD 1400 SS1
Gone but not forgotten: CAN 172D - Straight Six Coupe | GBG 540E - V6 Coupe | C999 YCR - 1600 SS1
View my website 'Scimitars e Cimitarra': http://jeffcraske.wix.com/index
AllingtonGT
Has thanked: 28 times
Post by AllingtonGT » Thu Sep 07, 2017 12:48 pm
Thanks Victor. Your approach, diligence, commitment and execution are an inspiration. You make us smile :D Very much looking forward to seeing completion.
Archibald Tyre
Post by Archibald Tyre » Thu Sep 07, 2017 1:23 pm
Something tells me that the body will be better than anything that came out of the reliant factory.
I hope he drives the car once its done, many would be too scared to risk spoiling it.
Nigel Clark
Been thanked: 45 times
Post by Nigel Clark » Thu Sep 07, 2017 4:11 pm
Like everyone here, I'm truly stunned, amazed, in awe...
The quality and ingenuity of Victor's work is simply so uncompromising. And well done for sticking to the vision and principles of the this very special coupé project. I can't wait for the next progress report.
Nigel
747PETE
Has thanked: 30 times
Post by 747PETE » Wed Dec 06, 2017 5:30 pm
I keep coming back to this thread for inspiration and a phrase keeps coming to mind..its often used by many but really is spot on here Victor.."Quality without compromise" .Thanks for sharing this!
mermar74
Post by mermar74 » Sun Dec 10, 2017 10:08 am
Continued from previous instalment;
Final Body Preparation
With the chassis now fully assembled and made ready, work will next focus on continuing with the body preparation and paint.
The last lot of work carried out on the body since its return from the repairer entailed re mounting the body onto the chassis for a trial fit all panels, glass, weather seals, and just about all else that attaches to the body. This extra work has been deemed necessary after the major task of gelcoat removal and GRP re skin of outer body surface.
This lengthy exercise highlighted several areas that require fettling for correct fit; these have all been noted and a lengthy rectification list drawn up to be passed onto the repairer.
My attention next turned to making new rain gutters; these are originally made from long aluminium strips formed to the shape of a J, and most crudely attached to the GRP with pop rivets.
The gutters on this car are in very poor condition and one side is broken into two pieces.
I made a start on these believing this will be a reasonably straightforward job, but after several attempts and much wasted time I failed to produce satisfactory results.
By now it became apparent making these will not be a simple task and will require a dedicated forming tool and a very soft grade of aluminium.
I next made contact with a few metal shaping works asking for a price to make these, but the quotes given were eye watering expensive.
This now forced me to undertake the complications of designing and making a 1.8 metre long forming tool to create the J shape. This form is made to adapt and work in conjunction with a long bed hydraulic press owned by an acquaintance.
Finding the correct aluminium also posed a problem as full soft aluminium sheet is not commonly stocked by most suppliers. Finding this material locally took much searching, but finally a sheet was sourced although at a premium price.
Armed with these, I started the fabrication by guillotining strips of aluminium from the sheet and experimenting using the forming tool and press. Once mastered I was able to shape a few, although successful forming could only be accomplished on strips cut wider than required. This extra width on both side edges will now need to be trimmed; not a simple task on such fragile formed lengths of aluminium.
I ran out of ideas on how to trim these without damage, so I next visited an engineer friend to ask for advice. It came as a relief when he pointed towards a specialised blade saw amongst his equipment that would be ideal for such a task.
With some careful setting up he was able to successfully slice the excess material off both sides of strips and leave neat edges much to my delight.
With this now done, the next few days were spent fitting, fettling and shaping these new gutters to fit along the body. Small screws have been used to affix these neatly to body, doing away with the unsightly rivets. In the end all turned out well and I now have new gutters.
As with all else on this build, making these parts has consumed far more work, complications and expense than first anticipated.
I have made a few extra gutters if anyone is interested in purchasing.
The body fit out has now been completed, and the body again dismantled, lifted off the chassis and re fitted to the cart. Arrangements were made with the body repairer to carry on with the rest of bodywork, and the body again delivered to his premises.
Several weeks have since past, and work on the body has well progressed.
The work being carried out by my long time acquaintance is of the highest order, and he has left no stone unturned to produce the best results. It takes a most determined mindset and a great deal of laborious work to achieve a flawless GRP finish, and the results of his work clearly speak for themselves.
As a side note, my thoughts on bodywork;
I am not afraid to tackle most auto restoration jobs regardless of challenges, but I strictly draw the line at undertaking GRP bodywork especially when filing and sanding fibreglass for weeks on end is involved. I hold those who willingly undertake such unpleasant and filthy work in high esteem, and praise their perseverance.
There are certainly not many repairers around here interested in taking on such work, and I am most fortunate my car is in good hands.
With the bodywork now well advanced, the time has come to settle on the paint colour. None of the original Coupe factory colours are to my liking, so this opened my choice to any colour on the planet.
Body colour can become a big decision in a car build, and I have deliberated for years on which colour to choose. Early on in the build I set a few basic criteria’s for the colour, these included;
Only straight colours; no metallics or fancy paints,
Preferably a light colour due to Australian hot climate,
Colour must be from era when this car was first made.
After much deliberation and change of mind I finally settled on a colour; this will be revealed at a later stage after the body has been painted.
To be continued:
Victor Pace
Post by DARK STAR » Sun Dec 10, 2017 10:25 am
Original gutters are rather makeshift.
I reseated mine with Sikaflex but the door frame tends to touch the rivets.
Rivets in fibreglass, sometimes I wonder if Reliant knew what they were doing :roll:
Body looks good ...
td99
Been thanked: 22 times
Post by td99 » Sun Dec 10, 2017 6:38 pm
Victor, your dedication to perfection is awesome,as are your talents! Wonderful thread.
Trevor - 1800Ti daily driver
1800Ti DET project, RAV4
Scott
Post by Scott » Tue Dec 12, 2017 12:03 pm
Victor had you made rain gutters for a 5a I would have your hand off!!
I almost let out a little scream of excitement when I saw you had posted this recent update :D
Unfortunately I fear you would never take on a scimitar as a project again, however if you did look at a 5a you make me very happy (I would be your first customer!)
