Adjusting valve clearance
Eric2205
Post by Eric2205 » Mon Aug 12, 2019 4:42 pm
Hello,
On my Se5a yesterday I had to adjust the valve clearance
I made the adjustment about 1000 miles ago.
For valve 1 it was essential
Two pics with the help of my wife
Is this current on an Essex?
tony1966
Post by tony1966 » Mon Aug 12, 2019 4:45 pm
adjusting nuts might not be gripping well enough-sure i have heard of folk squeezing them in a vice
Eric2205
Post by Eric2205 » Mon Aug 12, 2019 4:50 pm
Or replace them with new ones?
Been thanked: 87 times
Post by Old and Slow » Mon Aug 12, 2019 5:49 pm
Use a drop of your pink nail varnish to mark where the nut is screwed to, and then see if the nut has moved after a few miles? 8)
Eric2205
Post by Eric2205 » Mon Aug 12, 2019 7:06 pm
Very good idea, I will borrow this discreetly in the drawer of my wife
tony1966
Post by tony1966 » Mon Aug 12, 2019 7:10 pm
next time she helps you"re for the high jump lol
Post by Old and Slow » Wed Aug 14, 2019 10:00 pm
I woke up in the night dreaming about your pink nail varnish :shock:
I wondered about putting some on the rocker arm too, in case it's the stud unscrewing in the head, and not the nut loose on the stud.
Post by Roger Pennington » Wed Aug 14, 2019 10:31 pm
Probably best to gloss-over the nail varnish incident......
The studs aren't screwed-in as standard, they're just an interference fit. (They sometimes push out if you have a timing gear failure, and valves hit pistons). If you think one might be coming out, you could put a straight edge across their tops?
Eric2205
Post by Eric2205 » Wed Sep 04, 2019 2:49 pm
Hi,
I'll find new adjusting nuts, i'll change them ... in 800 miles
Eric2205
Post by Eric2205 » Wed Sep 04, 2019 2:50 pm
Has thanked: 64 times
Been thanked: 196 times
Post by gtcse8 » Wed Sep 04, 2019 6:48 pm
Assuming the stud is NOT pulling out of the head, checked by putting a straight edge over the tops of the studs.
Eric save your money and just unscrew the original nut and place it on a solid flat surface and just hit the top with a large hammer.
IF you buy the used nut how do you know this is not loose too :?: :cry:
Eric2205
Post by Eric2205 » Thu Sep 05, 2019 8:53 am
Hi,
I'll check the stud before and I'll try the hammer before
