Se5 connection heater valve to inlet manifold
Jon69
Post by Jon69 » Fri May 10, 2019 9:44 am
No luck in wanted section, so can anyone help with the adapter pipe and nut that connects the heater valve to inlet manifold, or even an inlet manifold with the connection complete. Must be Se5 figment.
Having found a correct heater valve, now need parts to connect to inlet manifold.
The original manifold had a wrong valve fitted to a connector which was also wrong and would never have worked.
Has thanked: 129 times
Been thanked: 938 times
Post by scimjim » Fri May 10, 2019 10:51 am
it's coupe/SE5 - sorry no idea of source.
1969SE5
Post by 1969SE5 » Fri May 10, 2019 11:44 am
had same issue with mine, i bought 2 specialist fittings from the Net once i had established the threads and dimensions.
Been thanked: 347 times
Post by peter freeman » Fri May 10, 2019 1:52 pm
Someone fitted a campervan valve.
campervan valve.jpg (77.44 KiB) Viewed 286 times
1969SE5
Post by 1969SE5 » Fri May 10, 2019 3:12 pm
i tried the the Taxi valve that is well published, but did not operate well with the rotary dials, so sourced the real thing..........
Jon69
Post by Jon69 » Sat May 11, 2019 6:24 pm
Thanks for your replies.
1969SE5, what unions/connectors did you find to do the job?
