rear wheel bearings
- RSSOC Member
- Has thanked: 25 times
rear wheel bearings
hi need some advise again we have had a noisy near side wheel bearing for a while now so finally got around to replacing it this Friday ,took it out this morning for a test drive and this side was fine no noise at all but when cornering left I now have a much worse noise coming from the off side. when I replaced bearing on near side I left the shims the same , so is this a endfloat issue or a wheel bearing need doing on the opposite side also ? any advise on where to go with this would be great cheers
- scimjim
- RSSOC Member
- Has thanked: 116 times
- Been thanked: 853 times
rear wheel bearings
Probably endfloat, it should be checked if the halfshafts are disturbed.
- RSSOC Member
rear wheel bearings
which do you think would cause the noise from opposite side wheel ? too little end float or too much . will it be awkward to measure endfloat now with grease in and hubs refitted ?
- RSSOC Member
- philhoward
- RSSOC Member
- Has thanked: 43 times
- Been thanked: 539 times
- Contact:
rear wheel bearings
I assume that was 0.005” (5 thou) and not 5 thousandths of a thou!
5 thou can make all the difference if it’s not where it should be.
- scimjim
- RSSOC Member
rear wheel bearings
Is that 5 thou over the 4-8 thou you need?
- RSSOC Member
- Has thanked: 11 times
- Been thanked: 81 times
rear wheel bearings
Having done a few rear axle bearing renewals I have found that the only reasons for noise AFTER replacing One side has been either.
The other side bearing is worn/damaged, And should have been replaced or the shimming was NOT equal on the sides, so the noise is actually the preload pushing the orbital gears sideways inside the axle.
- RSSOC Member
rear wheel bearings
yeap thats what it was the too much shimming on the new side ,sounds better now than it has since we bought it
- scimjim
- RSSOC Member
rear wheel bearings
Always good to hear other people’s experiences - a project thread for your car is also a useful reference point and even a history if you ever sell?
