SE5 Filler neck hose - HELP !!
1969SE5
Post by 1969SE5 » Thu May 10, 2018 12:44 am
Tending to agree Jim.
roymck
Has thanked: 15 times
Been thanked: 23 times
Post by roymck » Thu May 10, 2018 8:56 am
The neck is what people called Pot metal , Aka Mazac or Zamac , want to weld that no chance . As Jim said looking at the Tank neck looks a more likely prospect to alter . Whatever you do you are restricted on space if you want to refit the inner panel it’s not insurmountable just bloody difficult .
I can understand why Reliant altered the cap after 500 cars
fightingtorque
Post by fightingtorque » Wed May 16, 2018 3:40 pm
I have the same combination of vertical cap and stainless tank with the pipe coming at 45% as you do.
I bought a hose which has 45% bend, fluoro lined, and different diameters at each end from here: http://www.autosiliconehoses.com/silico ... lbows.html
It needs to be fluoro-lined, otherwise it will grow in length with the fuel vapour. I think this is an option you can specify on any of those hoses.
It's still a difficult fit requiring lowering the tank to get it on if I remember rightly.
1969SE5
Post by 1969SE5 » Wed May 16, 2018 3:48 pm
thinking of taking the tank out, and getting the neck reshaped to suit, with the angles as they are, can't see filling being very easy otherwise.........
