Probably a really easy solution
james7759
Post by james7759 » Fri Mar 23, 2018 4:17 pm
... Am I missing something or is their a trick to removing the back section of the rear seats? I can lift them up on a hinge type bracket but can't see how to unbolt them.
1969SE5
Post by 1969SE5 » Fri Mar 23, 2018 4:26 pm
should be 3 cross head screws facing toward the back of the car for both hinges, under the carpet backing.
scimmy_man
Been thanked: 32 times
Post by scimmy_man » Fri Mar 23, 2018 4:58 pm
the outer ones WILL be seized, drill the heads off, the inner ones being oiled, will come out easily.
