Ignition switch wiring help!
1949bug
Post by 1949bug » Fri Feb 23, 2018 4:34 pm
Finally got the car to run after a 29 year sleep.
The ignition barrel was broken and someone pulled the wires and left them hanging below the dash plugged Incorrectly.
I can start the car with ignition on but only my manually contacting the solenoid wire directly on the starter.
Fitted is a Lucas 157sa (I assume is correct fitment)
Has positions
1 - 1 pin
5 - 2 pins
3- 2 pins
2 - 2 pins
I have 4 wire terminals
In the workshop manual there is no information on which wires go to each pin!?
I’m guessing
White - ignition?
Brown - ground?
White/red - starter solinoid?
White/pink - ignition lamination?
But even with the correct information I’m still lost on the PIN numbers.
Thanks in advance
Post by scimjim » Fri Feb 23, 2018 4:42 pm
1949bug
Post by 1949bug » Fri Feb 23, 2018 4:53 pm
Much appreciated 8)
Post by scimjim » Fri Feb 23, 2018 5:40 pm
Archived in the members only section but taken from google.
747PETE
Has thanked: 30 times
Post by 747PETE » Fri Feb 23, 2018 8:50 pm
Following on from that,this is the reverse of my one
LUCAS 39415 157SA Trying not to confuse you!
1949bug
Post by 1949bug » Sat Feb 24, 2018 11:34 am
LUCAS 39415 157SA Trying not to confuse you!3041B1F9-1880-4BEA-8405-030F96B417BE.jpeg
That’s what mine looks like!
1949bug
Post by 1949bug » Sat Feb 24, 2018 9:06 pm
All wired up and working beautifully 8)
