Clutch slave cylinder seized
westofsouth
Post by westofsouth » Wed Jan 24, 2018 10:43 am
Trying to move my SE5 (stored for many years in the back garden).
Gaining access to the slave cylinder looks very difficult.
Any suggestions?
It has a galvanised chassis fortunately.
Been thanked: 876 times
Post by scimjim » Wed Jan 24, 2018 10:50 am
As an SE5, it should have had a 2 rod gearbox originally - which means the alloy slave cylinder is secured into the iron bellhousing and locked with a circlip. Best accessed from underneath but often seized in position.
Post by scimjim » Wed Jan 24, 2018 10:51 am
In fact, you already asked the question here :D
westofsouth
Post by westofsouth » Wed Jan 24, 2018 3:03 pm
dooh... :oops:
Post by Coupe Racing » Wed Jan 24, 2018 5:16 pm
With some fiddling , the seals can be changed in situ , just make sure the bore is not corroded or scored
