pinion oil seal leak
he trys hard
Has thanked: 22 times
Post by he trys hard » Sat Oct 28, 2017 9:05 pm
hi recently had a leak from pinion oil seal which after a couple of attempts at getting correct seal was replaced and repaired but I still have a leak with new seal fitted ,could it be that I need to replace the flange ? which did have a wear mark where the old seal had been running. if so are these available as spare? any advise/ ideas much appreciated thanks ian
Diyhell
Has thanked: 54 times
Been thanked: 11 times
Post by Diyhell » Sat Oct 28, 2017 9:16 pm
I've done two on my SE6A (replaced axle) and both had some wear but sealed fine after replacement.
There is the elusive breather hole on my type, which I read can lead to an over-pressurising of the axle and oil being pushed out if its blocked. Not sure if it's the same on your axle?
SE6a needing lots of work...
Been thanked: 283 times
Post by peter freeman » Sat Oct 28, 2017 9:23 pm
Are you sure its leaking at the flange (inner) and not from the outside of the seal - I put a bit of blue on them when fitting. The flange can be put back to original dims at a good metal shop.
he trys hard
Post by he trys hard » Sat Oct 28, 2017 9:28 pm
yes have unblocked the breather prior to seal replacement unless there is another mine was on the right hand axle tube viewed from rear? , it was blocked solid when I found it lol
he trys hard
Post by he trys hard » Sat Oct 28, 2017 9:32 pm
no I'm not sure where its leaking from peter, I did consider this was very snug fit maybe start here with new seal . how is the flange brought back ?
Has thanked: 113 times
Been thanked: 750 times
Post by scimjim » Sat Oct 28, 2017 9:39 pm
I recall someone sleeving the pinion flange - maybe Christian (Pepe)?
Post by peter freeman » Sat Oct 28, 2017 9:39 pm
They turn a bit off then sleeve it - obviously the sleeve has a outside dimension same as the original outside dimension/
Post by scimjim » Sat Oct 28, 2017 9:51 pm
Speedi sleeve - pics here
he trys hard
Post by he trys hard » Tue Nov 21, 2017 10:48 pm
ok so speedi sleeve fitted many thanks for the link ...but still have small drip after a run grr! . so is there more than one vent hole in diff/axle found the one right hand axle tube looking from rear just thinking its over pressurizing maybe ? all dry whilst parked up. any help appreciated
Post by scimjim » Tue Nov 21, 2017 11:00 pm
Only one vent - is it still leaking from the nose after a sleeve and new seal?
Post by peter freeman » Tue Nov 21, 2017 11:02 pm
I had one where the oil came up the thread - you would not think it would get out but it did.
he trys hard
Post by he trys hard » Wed Nov 22, 2017 7:39 pm
yes still leaking after fitting sleeve didn't replace seal again as it only ran about 5miles on new seal prior to fitting sleeve,i did read somewhere peter that it was possible for the oil to come back the spline and out behind nut and washer what is the best way to prevent this?
Been thanked: 69 times
Post by Coupe Racing » Wed Nov 22, 2017 8:18 pm
Have you fitted the rubber type radial oil seal or the leather type
he trys hard
Post by he trys hard » Wed Nov 22, 2017 8:29 pm
later rubber type from gw's
Post by peter freeman » Wed Nov 22, 2017 8:46 pm
I wrapped the thread in plumbers tape - not a lot needed and it cured my leak.
