Garage exhaust extract hoses
drcdb15
Has thanked: 28 times
Been thanked: 24 times
Post by drcdb15 » Fri Aug 10, 2018 5:38 pm
I'm sure this has been discussed before but blowed if I can find it...
I want to get some hoses so I can run the car in the garage without rapidly soaking everything in water and myself in carbon monoxide. Has anyone got either and off the shelf or a home brew solution to recommend please ? Thanks
I should add, I know about the Sealey kit available from Machine Mart etc, but I was thinking in terms of something more simple and cheap, like maybe just two hoses from the exhaust to the outside world.
Chris
halfpenny
Post by halfpenny » Fri Aug 10, 2018 6:05 pm
Vacuum cleaner hose is cheap and effective
drcdb15
Post by drcdb15 » Sat Aug 11, 2018 6:52 pm
Have you actually tried this ? I wondered if the small bore of this hose might just throttle the engine?
Chris
halfpenny
Post by halfpenny » Sat Aug 11, 2018 7:56 pm
Yes, but just enough (2m) to get under the garage door and round the corner. No noticeable effect, but obviously a long length will increase back pressure.
Been thanked: 87 times
Post by Coupe Racing » Sun Aug 12, 2018 2:23 pm
Watch it doesn’t melt
