Arduino projects for auto electronics, mini ECU etc
For Automotive-related projects such as ECUs and microcontollers. For Scimitar and Sabre original equipment, please use the relevant model areas.
Been thanked: 206 times
Re: Arduino projects for auto electronics, mini ECU etc
Post by AJL Electronics » Sat Jul 23, 2016 10:40 am
It is starting to look like I may have to. Testing this morning shows that although the trigger would work, as the road speed increases and load reduces on the engine, so does the pressure. That means that the gearbox would probably drop out of kickdown early. That does happen with mechanical kickdown of course so I will need to try it out both ways.
Has thanked: 41 times
Been thanked: 525 times
Post by philhoward » Sat Jul 23, 2016 12:46 pm
At least you can adjust your threshold based on your road speed?
Post by toomanysabres » Sat Jul 23, 2016 3:51 pm
Not really anything to do with this I think BUT I was in Salt Lake and I had been invited round to a colleague for dinner. While er-indoors was cooking, matey and I went for a ride up a canyon to a ski resort (Summer by the way) long bendy climb and at some point I thought there was a motor bike in my blind spot but no it was the auto gearbox violently and rapidly oscillating between 2 gears. It was a gutless 3.6litre coupe tank hire car. Good job it wasn't my car. Locking into an intermediate gear shut it up!!!
simmit
Has thanked: 120 times
Post by simmit » Tue Oct 04, 2016 9:43 pm
[quote="AJL Electronics"]Calibrating standard fuel gauges with non standard senders
"Circuit is dead simple. One Arduino Nano. Sender signal connected to A1 with a matching resistor to a 5V regulator (Nano cannot provide enough current), Output from D9 into a 2K resistor which feeds the base of a TIP120 Darlington pair. Fuel gauge is wired to the collector, other side fed from 10V stabiliser as normal. I haven't tested it with a switching regulator, but can't see why it shouldn't work."
I much appreciate your help but the information is way beyond me. Is there a simple and readily available gubbins, at sensible price, that will sort my problem?
Return to “Automotive Electronics”
