Fuse & relay boxes - base plate
Has thanked: 186 times
Been thanked: 1264 times
Re: Fuse & relay boxes - base plate
Post by scimjim » Fri May 14, 2010 1:30 pm
update: JohnMorris, Moschops and Roger P have ordered, Chats371 & scimrick still to get back to me and Pauluspaolo is first in line for the next batch.
scimrick
Post by scimrick » Fri May 14, 2010 9:22 pm
Jim,,
please add me to list, regards, Scimrick
scimjim wrote:Just to clarify, I counted these ase expressions of interest:
JohnMorris wrote:Looks good. I'm interested.
John
pauluspaolo wrote:Cool looking bit of kit - shame it'll be almost invisible when fitted :roll: I could be tempted to buy one (depending on price) as mine looks like it's been at the bottom of the English channel for the last 25 years! :)
chats371 wrote:Count me in as another interested party.
Chats
Moschops wrote:Don't forget me!
Will they come with a manufacturer's serial number carved into them? :)
please let me know if you are still interested - I hope to have four more next week but no promises.
Post by scimjim » Tue May 18, 2010 10:25 pm
cheques received from Scimrick, Moschops & Roger - base plates will be posted tomorrow.
scimrick
Post by scimrick » Fri May 21, 2010 5:46 pm
plate received today, Fri 21st, much thanks
Richard
Post by scimjim » Fri May 21, 2010 6:28 pm
excellent - hopefully it's quite self explanatory but If anyone requires any assistance in fitting, please let me know, in all cases please make sure you disconnect the battery first
Post by Roger Pennington » Sat May 22, 2010 7:26 pm
Received mine today, many thanks Jim :D
chats371
Post by chats371 » Sat May 22, 2010 8:38 pm
Definately still want one Jim. PM sent.
Chats
Own a 1986 SS1 1600 was going to be a 1800Ti after Full rebuild but now gonna stick a 1.8 Zetec 130bhp in!.
1999 Lotus Esprit GT3 which has now been sold :-(
Post by scimjim » Wed Jun 09, 2010 8:57 pm
4 plates sold - 3 more made this week and 2 just sold to the Club secretary today - so I have one more available and "real work" will mean there's no more produced for a few weeks, so first come - first served :D
Post by scimjim » Wed Jun 09, 2010 9:24 pm
last one sold 8)
if anyone else wants one, please post here or PM me.
JohnMorris
Post by JohnMorris » Tue Jun 29, 2010 9:25 pm
I still want one. Hoepfully there will be another batch? I didn't get your PM - it was marked removed by sender - but I admit I hadn't looked at the website for about a month. May/June is/was a hectic time of year but I have retired from that job now. As before, no rush.
John
1989 SS1 1600 standard
Post by scimjim » Tue Jun 29, 2010 10:04 pm
mods - any idea why? I certainly didn't recall a PM (and haven't actually looked to see if the function is even possible)
Has thanked: 130 times
Been thanked: 871 times
Post by philhoward » Tue Jun 29, 2010 10:16 pm
scimjim wrote:mods - any idea why? I certainly didn't recall a PM (and haven't actually looked to see if the function is even possible)
If you delete it from your outbox before the recipient has read it, then that will happen...but we did have a "glitch" with the database a while back where some outbox messages were lost :oops:
RichardKC6
Post by RichardKC6 » Wed Jul 28, 2010 3:49 pm
Potentially interested here - I'm trying to sell the car, but I noticed the base plate was a bit manky when adjusting the bonnet catches. If it's not a total PITA to swap over then looks like a bargain to get rid of the most obviously "grotty" bit in an engine bay!
2008 Citroën C6 (C6 RTK) and '93 Jeep Cherokee 4.0
SS1 gone, but not forgotten - next year ;)
133 cars in 18 years and thinking it's got to stop sometime, right? Please?
Post by scimjim » Wed Jul 28, 2010 6:29 pm
10 minute job unless you find a mess of bodges below the fuse box that needs fixing :?
Here's one I did this weekend:
disconnect battery, remove fuse box cover, remove ALL relays (you have to remove relay 5 to access the corner screw but you need to remove them all to get the block through the hole, so you may as well do it while it's all bolted down). Remove the 4 screws from fuse block base & 4 screws from the relay block base (it's easier to remove these BEFORE removing the base plate mounting screws) - then remove the 4 base plate mounting screws:
twist block bases so that they pass through the holes:
refitment as they say, is a reversal of removal. Note that this base unit was the prototype and has larger mounting holes - new ones are supplied with pilot holes only.
unfortunately, I don't have any available at the moment :( will keep you updated.
Post by scimjim » Thu Aug 26, 2010 6:28 pm
ok - three more plates ready and primed (not the ones below but you get the idea :D ).
Price is STILL £25 plus £5 P&P to members, £30 plus £5 P&P to non-members. This is a fit an forget replacement, they're alloy, so won't rust.
Holes for the black holders are pre-drilled, the four to secure to the car are pilot drilled and will require opening up.
replies on here or PM me for orders please
