SE5/A CILL / SILL? BODY REPAIR INSERTS
Been thanked: 81 times
Post by gtcse8 » Fri Apr 27, 2018 8:58 pm
After numerous requests and a quite a few sets remanufactured out of Zinc galvanised plate I have a couple of sets available.
A lot of work has gone into making them so they come in at £12 each plus post.
I`m not aware of anyone else offering these items, or able to do so.
SE5/A CILL / SILL? DOOR SUPPORT INSERTS
Post by Oaksey » Fri Apr 27, 2018 9:10 pm
Is that price correct, Mark?
Post by gtcse8 » Sat Apr 28, 2018 6:03 pm
Yes Josh
£12 each, there's a lot of time going into all those bloody holes, wish I had the 6K machine that would stamp the holes quicker.
Do you know anyone else making them cheaper?, if so grab them.
Post by Oaksey » Sat Apr 28, 2018 6:20 pm
Okay Mark, was just checking as they sounded cheap. Are these the ones that go up the front of the door or the ones underneath the doors?
DarrylWebb
Has thanked: 70 times
Post by DarrylWebb » Sat Apr 28, 2018 6:51 pm
That does sound good value, but as Josh says, some clarification is required as to whether we're talking about repairing
Sills
or A-post
Post by gtcse8 » Sun Apr 29, 2018 9:42 am
Heading Amended for a better description, but the other parts could also be fabricated?.
They are the Multi Holed, bottom inserts that are in Darryl`s top picture.
I have ONLY one set left out of the last set I made.
Made from thicker Galvanised sheet so they should last a lot longer than the originals.
More could be made if enough interest, but they will NOT be £12 each.
derekoss
Post by derekoss » Sun Apr 29, 2018 11:17 am
Would it not be easier to lay up that area with carbon/epoxy ?
Derek
sciminwales
Post by sciminwales » Sun Apr 29, 2018 10:23 pm
If you still have the last set could I have them please.
Paul
Been thanked: 115 times
Post by ScimmyMike » Sun Apr 29, 2018 10:35 pm
If you are making some A post ones Mark can I bags a pair for my 5a please, non galv
Post by gtcse8 » Mon Apr 30, 2018 12:50 pm
Hi Mike
I don`t have an A post to copy, so if anyone has a trashed or better still complete one that I could beg steal or borrow to get the measurement's from I would do them a deal on the first batch?.
I DO however have the small folded stiffener plates as shown in the top of Darryl`s bottom picture.
While I`m on line I can now announce that the revised cost of the new Galved Cill`s comes in at £15 each, and post is £6.50 insured.
I have requests for 3 more sets so I will produce 5 sets leaving 2 sets up for grabs.
Lead time around Two weeks.
doncontrols
Post by doncontrols » Mon Apr 30, 2018 2:38 pm
Mark, could I have a pair, please? Let me know payment method.
Thanks, Don
Been thanked: 472 times
Post by Roger Pennington » Mon Apr 30, 2018 5:30 pm
Might be worth a scan through this sticky thread - SE5a A-post dimensions / diagram for photos and info on the A-post reinforcing metalwork, and detailed drawings :)
Post by gtcse8 » Mon Apr 30, 2018 5:43 pm
Cheers Roger.
Dave, Lambrettald also pointed this out.
Will look at costing and also grab crusty to see who made his.
Don you have PM.
Post by gtcse8 » Tue May 01, 2018 8:25 pm
Right everyone interested. :!:
I have printed the drawings from the sticky on A POST dims and compared them to my physical samples and cars.
There are a few problems with the screw mounting holes I have found. :w
It would appear that the factory plonked the parts into the car and then drilled the holes that were required to assemble the cars. :roll:
Biggest challenge I will have is convincing purchasers that I have not got the holes wrong just that they must re use their existing holes. :idea:
This is shown in the following pictures of the copied parts I already have, most of the smaller holes don`t match the drawings.
Some of the mounting points I can slot to help assembly but this all adds to the time and ultimately final costs. :?:
Many thanks to every contributor on the A Post fabrications and I cannot afford to fall into the old trap of producing items under the offer of a sale and then not getting my outlay back, been there and have a lot of stock un sold. :cry:
Maybe one day I could list it all and retire :shock:
Has thanked: 24 times
Been thanked: 34 times
Post by Alan SS1 » Fri May 04, 2018 12:57 pm
and this surprises you? ? ? ? ? :shock: not
I think I might have some A post panels, I thought they were left over from a Robin rebuild, but obviously from the SE5a !!! need to dig them out from scrap pile as they were not too rusty . . .
