Triangular nose brackets/plates
Has thanked: 81 times
Been thanked: 213 times
SE5 & SE5a FRONT TRIANGLES FOR SPARE WHEEL SUPPORT
Post by gtcse8 » Mon Feb 13, 2017 3:22 pm
As heading.
I have been asked to reproduce the Triangular supports for the Air duct and spare wheel support plate on the SE5a.
I can`t price them reasonably unless I make a few pairs so I`m gauging support for remanufacture.
If anyone out there is interested please get in touch so I can get a Group purchase, just like the front nose supports.
These will be cut and folded from 1.6mm Galvanised sheet so will/should outlast me.
maestroman
Re: SE5a FRONT TRIANGLES FOR SPARE WHEEL SUPPORT
Post by maestroman » Mon Feb 13, 2017 3:54 pm
hi there,
I would definitely be interested
Stephen
http://s843.photobucket.com/albums/zz351/maestroman1/
lambrettald
Post by lambrettald » Mon Feb 13, 2017 4:15 pm
Hi Mark - me too please as discussed previously
Cheers Dave
Post by gtcse8 » Mon Feb 13, 2017 4:22 pm
Ok guys
That makes Three sets so far.
I will not be cutting the waterpipe hole in the passenger side, so it will not need blocking off as on my car.
Will probably be putting small slots for the lower bolts alignment into the chassis instead of the large holes also as on my car
limegreen5A
Post by limegreen5A » Mon Feb 13, 2017 4:51 pm
Mark,
yes, I'd been keen on a set.
Pete
Pete Fox
Monza Blue (was Lime Green!) '73 Se5a slowly being restored (slowly being the operative word!)
Crowther
Has thanked: 72 times
Post by Crowther » Mon Feb 13, 2017 5:33 pm
The temptation is powerful. I won't say yes just yet though. My car has the bottom radiator hose routed through the side plate, under the steering rack and into the water pump, so there is a hole in the plate. Would that be an option? If not what is the alternative route from radiator to pump?
Post by gtcse8 » Mon Feb 13, 2017 6:03 pm
Great Pete
We are getting there.
Four sets possibly so far
Chris the radiator pipe on the drivers side has to go through the steelwork unless you radically change the rad and pipework.
The parts in question are, with Reliant`s description.
R207669 Nose bracket RH with hole,( driver side ).
R207670 Nose bracket LH with hole, ( pass side ).
It would also appear that they are also for the early SE5 too?.
I have altered the request accordingly to see if SE5 owners are interested LOL.
Quite why Reliant put a large hole in the Passenger side is beyond me as the air escapes through it rather than pushing through the Rad??.
I have blanked mine off.
They probably got the Sheet metal workers to stamp out One shape then just bent the flanges to suit the LH or RH fitment for ease of manufacture.
Which is why I intend leaving #207670 blank as I`m only manufacturing a small quantity and can modify/alter parts to suit within budgets.
Crowther
Post by Crowther » Mon Feb 13, 2017 6:10 pm
Once again I have failed to properly read your excellent descriptions. You're quite right. The hole I was referring to is indeed on the DRIVER's side.
Re: SE5 & SE5a FRONT TRIANGLES FOR SPARE WHEEL SUPPORT
Post by gtcse8 » Mon Feb 13, 2017 6:14 pm
No probs Chris LOL
I some times just see the underlying description an jump in with both left feel Ha Ha
NYorkshireman
Post by NYorkshireman » Fri Feb 24, 2017 7:50 pm
Beware the triangular panels are different for Se5 and Se5a. Bolts holes in different places and slightly different shape. When you get both types together you can see the difference.
regs
Graeme
RSSOC1698
teesside.scimitar@ntlworld.com
SE5, SE6 V8, SE6a LHD, GTC, Middlebridge
lambrettald
Post by lambrettald » Tue Feb 28, 2017 6:37 pm
Hi Mark - any progress on possible remanufacture of these and any idea of cost
Cheers Dave
Post by gtcse8 » Wed Mar 01, 2017 9:18 am
Dave, not had chance to take them off my SE5a and get the sizes drawn.
And I not got hold of asset from a 5 yet.
Rough guess would be about £40 a set, but the more I make the cheaper the steel costs.
Post by gtcse8 » Mon Aug 28, 2017 11:51 am
As I have now started production of these triangular brackets I have found a problem with the THREE cars I own. :(
ALL of them have slightly taller plates on the drivers side!!!!! :!:
Or left hand when looking into the engine bay.
I find this odd as my cars are 1973 & 1974, plus the 1976 late car that I have looked at has the same problem. :|
It means that the spare wheel resting plate gets distorted when bolted down. :x
Has anyone else noticed this fault as I find it strange that someone in production at Reliant should have noticed this manufacturing fault, or am I just unlucky??. :w
I will rectify the problem on the new ones but as I have made the blanks now I shall have to find a way to rectify. :cry:
lhs above.JPG (236.35 KiB) Viewed 3733 times
lhs step.JPG (121.54 KiB) Viewed 3733 times
rhs above.JPG (233.48 KiB) Viewed 3733 times
rhs gap.JPG (180.51 KiB) Viewed 3733 times
Has thanked: 131 times
Been thanked: 872 times
Post by philhoward » Mon Aug 28, 2017 10:51 pm
I think they may all be like that, Mark? I remember fighting with 2 different sets (second set because I though the first set were duff).
Post by gtcse8 » Tue Aug 29, 2017 10:36 am
Ok Phil
I think that too, as all the ones I have looked at are all folded slightly differently on either side by 1/2"
I am altering slightly the New ones so that everything lines up correctly anyway, don`t want complaints about my workmanship LOL.
I will also make bespoke units upon request, just as scimjim has, he does not need a few holes, captive nuts and horn mounting brackets which has shaved a bit off his final price so feel free to ask what`s available and the price may come down from the projected £25ish.
I can also supply a complete set of fixings if needed, all in HT zinc plated.
